New Digital Laser Photo Tachometer Non Contact - $8
koehler
http://www.ebay.com/itm/221942286516?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Features:
100% Brand new and high quality!
Large LCD displaying
Wide measuring range & high resolution. The use of durable.
Digital display gives exact RPM with on guessing or errors. It is a great tool to measure
In wood and metal working it can be used to accurately measure the speed of a lathe.
The RPM of motors and machine parts.
The housing has been carefully shaped to fit comfortably in either hand.
The last value/min . value will be automatically stored in memory and can be displayed by turn anytime.
Wide measurement range, high resolution
Large screen display, clear reading
light Weight and hard shell ABS plastic, nice shape, easy to use.
Products Properties:
Material:Hard shell ABS plastic
Mirror Length:L50 x W25mm
Battery length:L44 x W25 x D16mm
Item Type:Non Contact RPM Laser Photo Tachometer
Net Size:L130 x W65mm
Scan Diameter:17mm
Use for:Measure the speed of lathe motors and machine
Range: 2.5 to 99,999 RPM
Specifications:
Output: less than 1mw
Net Size: L130 x W65mm mirror
Length: L50 x W25mm Scan
Diameter: 17mm Battery length: L44 x W25 x D16mm
Package Size: L146 x W95 x D45mm
Packaging content:
1 x New Digital Laser Photo Tachometer Non Contact RPM Tach(NOT INCLUDE BATTERY)
3 x approx. 75cm of reflective stripes
1 x Reflective paper
Ha, the refill pack of reflective strips is also $8!
Razors & blades all over again.
But, this made me feel much better.
2Pcs 20W Waterproof LED 12V Daytime Running Light DRL COB Strip Lamp Fog Car
http://www.ebay.com/itm/2Pcs-20W-Waterproof-LED-12V-Daytime-Running-Light-DRL-COB-Strip-Lamp-Fog-Car-/272594907016?hash=item3f77ec2f88:g:Mr8AAOSwax5YzPpa&vxp=mtr
$USD 4.03
http://www.ebay.com/itm/112322299696
Now who needs their turbocharger turbine temp & RPM measured?
