Spin2 Operator Syntax - Page 6 — Parallax Forums
13468918
  • cgracey wrote: »
    Here is what I've got now. I think the aliases are important, though I got rid of them and put them back in a few times. This supports all the C operators. I kind of don't like C precedence, though, since too many parentheses wind up being needed - like NOT, for example, seems like it should have lower precedence, in order to work well with AND and OR. I almost want to separate ! and NOT and give them different precedence.
    gut feeling says the rules should be so that this is all possible without parentheses:
    IF A>5 AND ++B<=6 OR NOT C OR D - 1 <> E + 5 * 5
    meaning:
    ( (A>5) AND ( (++B)<=6) ) OR (NOT C) OR ( (D-1) <> (E + (5*5) ) )
    This seems pretty much in line with what Spin1 does.
    Seriously, much has happened since C was invented, and I think the Spin1 precedence is much more intuitive.
    As for the second part, that's a tough one but my vote is a definite no on ! and NOT acting different. There are already different symbols for a 1's complement and 2's complement.
  • Roy Eltham wrote:
    Chip, please do not listen to Phil about shutting out C. That is a mistake. Also, the Spin1 operators cause nothing but confusion and problems for new and old alike. Calling them a thing of beauty is a GIANT stretch.
    Roy, you're so used to programming in a truly ugly language (C), that you're apparently blind to the elegance of what Chip created in Spin. And I have never considered the Spin operators to be either confusing or problematic. Chip needs to forge his own path with Spin2. Based upon what he accomplished with Spin, I hope that he has the courage to follow his heart once again and ignore the influences -- including some of my own -- rampant in this thread. Spin is not C; C is not Spin. They do not need to have anything in common. Programming in C is work. Programming in Spin should remain fun.
  • jmgjmg Posts: 15,193
    Cluso99 wrote: »
    MAX == LMIN and MIN == LMAX
    Setting the maximum of two values is the same as limiting the minimum.
    x=5 and y=2 then MAX/LMIN will give x=5
    x=5 and y=8 them MAX/LMIN will give x=8
    Agreed PASM P1 is backward which is why I suggested using LMIN and LMAX there too for the P2.
    Otherwise, we have P1 and P2 doing opposite things for MIN and MAX !!!!!
    Yes, if P1 has effectively defined these bass-ackwards, then a new name is needed, but it needs to be quite clear on what the new one does.
    'Limiting the minimum' is too vague and verbose to turn into an opcode.
  • Sorry, Phil, but I strongly disagree. It's not just C. It's every other language out there for the most part. Every common language.
    Spin's operators have caused numerous problems for MANY users novice and expert. Just because you don't have an issue, doesn't mean MANY others don't.
    Chip has already got it working with the C/Verilog set of operators, and I think that is good. He seems to think so too.
  • TorTor Posts: 2,010
    As Roy says. It's not just C. It's nearly universal.
    I think this is the first time I have participated in a language war about a language that does not exist yet!
  • jmg wrote: »
    Aliases are not about being indecisive at all, far from it.
    They are done in other languages, and represent a careful choice to improve code clarity and code portability across programmers.
    What other languages have aliases for operators?
  • kwinn wrote: »
    Probably true, but a math teacher is not writing code on a computer with the limited number of characters a keyboard provides.
    I wonder why no language uses /= for not equal? That is the closest you can get to the standard mathematical notation. Of course, it wouldn't work for C because that is an assignment operator.
    I can't think of one.
    I presume we are not thinking about operator overloading in C++. Nor the contortions you can perform with Forth. I don't count things like "#define PLUS +" in C etc which is just a bad idea.
  • Heater. wrote: »
    Well, there is no #define in Spin so I think you're safe there.
  • David Betz wrote: »
    I think one of the ML variants uses "=/=" for not equal, but it's a little unusual. I think either "<>" or "!=" would be fine. I don't like the idea of aliases, though -- just pick one and stick with it.
  • You know, people keep saying here that Spin2 has to be different from Spin. I don't see why that has to be true except that PASM2 is different from PASM. There is no real reason that the high-level part of Spin has to be different. It seems to me that if Spin2 is the only language available for P2 at launch and with Spin2 being fairly different from Spin you end up with a processor that can't easily be adopted by either existing P1 users or people coming from another MCU. Isn't this shooting yourself in the foot? I know we are all experts and can make the transition from Spin to Spin2 pretty easily but what about the non-experts who are using P1? I would suggest keeping the high-level part of Spin2 a strict superset of Spin.
    David Betz wrote: »
    Here is a listing file, for an Assembler I just generated
       564:    008D  11 8C                                  CALL    SFR_Init
       565:    008F  80 FE                                  SJMP    $
       566:    0091  3E 2A                                  DB ">","*"
       567:    0093  1F                                     DB  0x1f
       568:    0094  1F                                     db  01fH
       569:    0095  0F                                     db  0000_1111b
       570:    0096  08                                     db 1 << 3
       571:    0097  08                                     db 1 SHL 3
       572:    0098  10                                     db 128 >> 3
       573:    0099  10                                     db 128 SHR 3
       574:    009A  03                                     db 15 AND 3
       575:    009B  03                                     db 15 & 3
       576:    009C  0C                                     db 15 XOR 3
       577:    009D  0C                                     db 15 ^ 3
       578:    009E  0B                                     db 8 OR 3
       579:    009F  0B                                     db 8 | 3
       580:                                 if 1 <= 4
       581:    00A0  0E                       db   14
       582:                                 else
       583:                                   db   4
       584:                                 endif
       585:
       586:                                 if 1 LE 4
       587:    00A1  0E                       db   14
       588:                                 else
       589:                                   db   4
       590:                                 endif
       591:                                 if 1 GT 4
       592:                                   db   14
       593:                                 else
       594:    00A2  04                       db   4
       595:                                 endif
    and see this PDF for IEC61131 which shows applied alias lists
    http://calc1.kss.ia.polsl.pl/content/dydaktyka/PC/PLC_IEC61131-3.pdf
    These are both very similar to Chip's proposals, but probably a superset, as you can see LE,GT etc supported too, which means Chip could add more aliases, and still not be pioneering ahead of what is already done.
    (except the ASM also allows both HEX numeric forms, of 12H and 0x12, that was added because tables often are generated in C-Hex form, and it is more common for C-tools to include assemblers that can accept 0x12 numbers too)
    You make a *very* good point here David. I wonder how much (non-PASM) Spin1 could be made to work on Spin2? I suspect most of it.
    edited 2017-04-12 11:32
    David Betz wrote: »
    To cover exactly this case, I did earlier suggest a mode switch, for where that 'strict superset' collides/conflicts with other demands.
    For those who are averse to a mode switch, a simple translator should be possible, that does P1_Spin to P2_Spin, to allow harvest of code, without forcing conflicts.
    Looks like a good chunk of such a Translator already exists here :)
    https://forums.parallax.com/discussion/166470/can-t-wait-for-propgcc-on-the-p2
    This s2p does the somewhat harder ASM translation.
  • AribaAriba Posts: 2,693
    David Betz wrote: »
    VHDL uses this
    VHDL:         /=
    LUA:          ~=
    Pascal:       <>
    Modula:       <>  !=
    Oberon:       !=
    Python:       !=  <>
    VisualBasic:  <>
    other BASICs: <> or #
    Also Python has aliases it supports both != and <> but != is recommended.
    Andy
  • jmg wrote: »
       580:                                 if 1 <= 4
       581:    00A0  0E                       db   14
       582:                                 else
       583:                                   db   4
       584:                                 endif
       585:
       586:                                 if 1 LE 4
       587:    00A1  0E                       db   14
       588:                                 else
       589:                                   db   4
       590:                                 endif
       591:                                 if 1 GT 4
       592:                                   db   14
       593:                                 else
       594:    00A2  04                       db   4
       595:                                 endif
    How about some examples from mainstream languages that some of us may have actually heard of?
  • MJBMJB Posts: 1,235
    Cluso99 wrote: »
    oh - LMIN is not LONG MIN ??
    another option for confusion
    I always wondered why in SPIN MAX and MIN are reversed ... compared to all the other languages I know ... (even Tachyon I use most on the Prop)
    so for 'universal' clarity ;-)
    MIN(x,y) gives the smallest of both (x,y) ... please
    then no LMIN and no mindbending needed ..
    edited 2017-04-12 11:45
    If the language is called SPIN2 then it should be as close to SPIN1 as possible.
    Otherwise it needs a new name.
    Switching between Propeller 1 und Propeller 2 programming in Spin will get much more tedious than switching between C and Spin now.
    Changing the operator precedence can result in hard to find errors in code translated from Spin1 to Spin2. You will need to check every expression with the old and new prededence in mind and set additional parentheses or remove them.
    Andy
    David Betz wrote: »
    Coming from a more hardware oriented background /= instead of != for not equal would have been fine by me. A / followed by characters is a common way of naming low true signals. Unfortunately it is already in use.
  • Re: SPIN 2 being different.
    A point I made early on. If we diverge too much, people will just fork SPIN 1, add PASM in line and go that way. Ersmith already put the basics for this out there.
    Honestly, I think people can live with the operator change. SPIN predicence rules are better kept though.
    Go beyond that, and it's an increasing worry.
    Not saying don't do it. Am saying it needs to be sweet, or it may not be adopted.
  • +1
    Sorry Phil, I strongly agree with Roy and the others on this.
    Roy Eltham wrote: »
  • rjo__rjo__ Posts: 2,114
    Operator precedence?
    Operator precedence is only important if you don't have to remember it.
    So... it isn't really important. Is it?
    I have no idea what the operator precedence is for Spin 1 and I'm certainly not going
    to learn it for Spin 2:)
  • Right!
    You didn't learn it because it made obvious sense. Whatever we do, preserving that is desirable, IMHO.
    I don't know, nor needed to know all of SPIN 1 rules, and for this reason.
    I never learn precedence rules because after the natural priority of the simple math operators, (+, - vs *, / etc) there is nothing obvious and I give up and bracket everything to make it clear what I want.
    Heater. wrote: »
    +1
    Heater. wrote: »
    That what I do, too.
    Okay. I feel good about this set, now. It's not entirely in agreement with anything else, but it makes the most sense to me. I want to know what you guys think:
    Operator	Term Usage	Assign Usage	Type		Prior	Description
    ++ (pre)	++x		++x		var prefix	1	Pre-increment
    -- (pre)	--x		--x		var prefix	1	Pre-decrement
    ?? (pre)	??x		??x		var prefix	1	PRNG reverse (var must be long)
    ++ (post)	x++		x++		var postfix	1	Post-increment
    -- (post)	x--		x--		var postfix	1	Post-decrement
    ?? (post)	x??		x??		var postfix	1	PRNG forward (var must be long)
    !! (post)	x!!		x!!		var postfix	1	Post-boolean NOT
    !  (post)	x!		x!		var postfix	1	Post-bitwise NOT
    \  (post)	x\y		x\y		var postfix	1	Post-set to y
    !		!x		!= x		unary		2	Bitwise NOT, 1's complement
    -		-x		-= x		unary		2	Negation, 2's complement
    ABS		ABS x		ABS= x		unary		2	Absolute value
    NCOD		NCOD x		NCOD= x		unary		2	Encode MSB, 31..0
    DCOD		DCOD x		DCOD= x		unary		2	Decode, 1<<(x & $1F)
    SQRT		SQRT x		SQRT= x		unary		2	Square root
    LOG2		LOG2 x		LOG2= x		unary		2	Unsigned to logarithm-base2
    EXP2		EXP2 x		EXP2= x		unary		2	Logarithm-base2 to unsigned
    >>, SAR		x >> y		x >>= y		binary		3, 16	Shift right, preserve sign
    <<, SHL		x << y		x <<= y		binary		3, 16	Shift left
    SHR		x SHR y		x SHR= y	binary		3, 16	Shift right, MSB's = 0
    ROR		x ROR y		x ROR= y	binary		3, 16	Rotate right
    ROL		x ROL y		x ROL= y	binary		3, 16	Rotate left
    REV		x REV y		x REV= y	binary		3, 16	Reverse y LSBs of x and zero-extend
    SIGNX		x SIGNX y	x SIGNX= y	binary		3, 16	Sign-extend from bit y
    &		x & y		x &= y		binary		4, 16	Bitwise AND
    ^		x ^ y		x ^= y		binary		5, 16	Bitwise XOR
    |		x | y		x |= y		binary		6, 16	Bitwise OR
    *		x * y		x *= y		binary		7, 16	Multiply
    /		x / y		x /= y		binary		7, 16	Divide, return quotient
    MOD		x MOD y		x MOD= y	binary		7, 16	Divide, return remainder
    SCAL		x SCAL y	x SCAL= y	binary		7, 16	Scale, unsigned (x * y) >> 32
    FRAC		x FRAC y	x FRAC= y	binary		7, 16	Fraction, unsigned {x, 32'b0}/y
    +		x + y		x += y		binary		8, 16	Add
    -		x - y		x -= y		binary		8, 16	Subtract
    #>		x #> y		x #>= y		binary		9, 16	Ensure x => y
    <#		x <# y		x <#= y		binary		9, 16	Ensure x <= y
    <		x < y		n/a		equality	10	Check less than			(returns 0 or -1)
    <=		x <= y		n/a		equality	10	Check less than or equal	(returns 0 or -1)
    ==		x == y		n/a		equality	10	Check equal			(returns 0 or -1)
    <>		x <> y		n/a		equality	10	Check not equal			(returns 0 or -1)
    >=		x >= y		n/a		equality	10	Check greater than or equal	(returns 0 or -1)
    >		x > y		n/a		equality	10	Check greater than		(returns 0 or -1)
    !!, NOT		!!x		!!= x		unary		11	Boolean NOT  (x == 0,            returns 0 or -1)
    &&, AND		x && y		x &&= y		binary		12	Boolean AND  (x <> 0 AND y <> 0, returns 0 or -1)
    ^^, XOR		x ^^ y		x ^^= y		binary		13	Boolean XOR  (x <> 0 XOR y <> 0, returns 0 or -1)
    ||, OR		x || y		x ||= y		binary		14	Boolean OR   (x <> 0 OR  y <> 0, returns 0 or -1)
    ? :		x ? y : z	n/a		ternary		15	Choose between y and z
    :=		x := y		x := y		assign		16	Set x to y
    edited 2017-04-12 23:11
    That looks quite good.
    Can AND OR XOR NOT be made to apply to both Boolean and Bitwise ?
    Should be possible to know if you have boolean as in
    IF (A >30) AND (A < 40)
    versus numbers, for bit-wise as in
    A := A AND $AA
    Other tools manage this ok.
    Other items besides operators :
    a) // is not allocated, and is now pretty much universal as a comment to end of line
    b) In the ASM example I gave above, all of $AA, 0xAA, 0AAH are valid hex numbers.
    The merit in supporting 0xAA form, is many tools export arrays in C-syntax hex, and being able to parse 0xAA means no editing of the lists is needed,
    Here is one example, from Silabs Clock generator tools
    # Si535x Registers Script
    # Part: Si5351A
    # Project File: <not saved>
    # Design ID: <none>
    # Includes Pre/Post Download Control Register Writes: Yes
    # Creator: ClockBuilder Pro v2.13.0.1 [2017-03-27]
    # Created On: 2017-04-08 14:45:54 GMT+12:00
    Address,Data
    0x0002,0x53
    0x0007,0x01
    0x0009,0xF8
    0x000A,0xF8
    0x000C,0x00
    0x000D,0x00
    0x000F,0x00
    0x0010,0x0F
    0x0011,0x8C
    0x0012,0x8C
    0x0013,0x8C
    0x0014,0x8C
    0x0015,0x8C
    0x0016,0x8C
    0x0017,0x8C
    0x001A,0x00
    0x001B,0xA0
  • jmg, I don't like that idea at all. I think they should be boolean only.
