Matrix Multiplication
in Propeller 1
Hello,
I am trying to find an example of how to multiply two matrices (for example, two 3x3 matrices) in C. Does anyone know of any tutorials online that explain this? I know I have to use pointers but I'm having a hard time grasping how to do this task.
David
David
void simple_mul(const float a[3][3], const float b[3][3], float out[3][3]) { int i,j,m,n; for(i=0;i<3;i++) { // for each output row for(j=0;j<3;j++) { // for each output column out[i][j] = 0.0f; // zero the value being computed for(m=0;m<3;m++) { out[i][j] += a[i][m]*b[m][j]; // accumulate the row & column multiplies } } } }Expanded out, it looks more like this:void mult(const Matrix3D & a, const Matrix3D & b, Matrix3D & out) { out.M11 = a.M11 * b.M11 + a.M12 * b.M21 + a.M13 * b.M31; out.M12 = a.M11 * b.M12 + a.M12 * b.M22 + a.M13 * b.M32; out.M13 = a.M11 * b.M13 + a.M12 * b.M23 + a.M13 * b.M33; out.M21 = a.M21 * b.M11 + a.M22 * b.M21 + a.M23 * b.M31; out.M22 = a.M21 * b.M12 + a.M22 * b.M22 + a.M23 * b.M32; out.M23 = a.M21 * b.M13 + a.M22 * b.M23 + a.M23 * b.M33; out.M31 = a.M31 * b.M11 + a.M32 * b.M21 + a.M33 * b.M31; out.M32 = a.M31 * b.M12 + a.M32 * b.M22 + a.M33 * b.M32; out.M33 = a.M31 * b.M13 + a.M32 * b.M23 + a.M33 * b.M33; }https://codeitaway.wordpress.com/2012/01/26/c-program-to-multiply-two-matrix-multiplication-of-3x3-matrix-in-c/
for (int i=0;i<3;i++) { for (int j=0;j<3;j++) { for (int k=0;k<3;k++) { resultMatrix[i][j] += firstMatrix[i][k]*secondMatrix[j][k]; } } }Each element in the product of matrices is the sum of the products of the row and corresponding column, so this produce the output of the sum of 2 3x3 matrices. Not very efficient with 3 nested loops, though.
Thank you for your replies. Apologies for getting back so late - been busy. Below is a piece of code I was working on when I posted my original question. It looks like I had something similar to your responses in terms of the algorithm. I think my main problem is passing matrices to a function - a matrix multiply function in this case. Do you have to use pointers to pass arrays to functions, and if so, how can I do this?
/* Matrix Multiplication with Floats.c Output in matrix form. */ #include "simpletools.h" // Include simple tools float p[3][3] = { {0.173, 1, 2}, {3, 4, 5}, {6, 7, 8.632} }; float q[3][3] = { {0, 1, 2}, {3, 4, 5}, {6, 7, 8} }; int main() // Main function { matrixMultiply(p, q); } matrixMultiply() // 3x3 matrixMultiply function { for(int i = 0; i < 3; i++) { for(int k = 0; k < 3; k++) { float sum = 0; for(int j = 0; j < 3; j++) { sum = sum + p[i][j] * q[j][k]; if(j == 2) { print("%f ", sum); if (k==2) { print("\n"); } } } }Respectfully,
David
But, they have a lot of baggage would wouldn't fit in a microcontroller...
void matrixMultiply(float p[3][3], float q[3][3], float r[3][3]) { for (int i=0;i<3;i++) { for (int j=0;j<3;j++) { for (int k=0;k<3;k++) { r[i][j] += p[i][k] * q[j][k]; } } } } [code] and call it as you have done: [code] float p[3][3] = {.....}; // First matrix float q[3][3] = {.....}; // Second matrix float r[3][3] = {.....}; // Result matrix matrixMultiply(p, q, r);In C the name of an array is actually a pointer, so for
int a[10];
"a" is a pointer to int. int *.
Thank you so much for your help. I was able to get it working
/* Multiply two 3 by 3 matrices */ #include "simpletools.h" float p[3][3] = { // Define matrix p {0, 1, 2}, {3, 4, 5}, {6, 7, 8} }; float q[3][3] = { // Define matrix q {0, 1, 2}, {3, 4, 5}, {6, 7, 8} }; float r[3][3] = { // Zero matrix r {0, 0, 0}, {0, 0, 0}, {0, 0, 0} }; float matrixMultiply(float p[3][3], float q[3][3], float r[3][3]); // Declare matrixMultiply function int main(){ matrixMultiply(p, q, r); // Call matrixMultiply function // Print matrix r print("r =\n"); for(int i = 0; i < 3; i++){ for(int k = 0; k < 3; k++){ print("%f ", r[i][k]); } print("\n"); } } // matrixMultiply function - compute a 3 by 3 matrix float matrixMultiply(float p[3][3], float q[3][3], float r[3][3]){ for(int i = 0; i < 3; i++){ for(int k = 0; k < 3; k++){ for(int j = 0; j < 3; j++){ r[i][k] = r[i][k] + p[i][j] * q[j][k]; } } } }Respectfully,
David
I'm sure you can imagine that the line:
is executed 3 * 3 * 3 = 27 times as all those loops go around.
On each execution i, j, k have some value between 0 and 2.
So one optimization would be to get rid of all the loops and write out that line 27 times with the correct numbers instead of i, j and k.
That would get rid of all the instructions that do the loop jumping, incrementing and testing of i, j and k. It would just run through a straight line of 27 statements that are actually doing the work you want.
This kind of optimization is known as "loop unrolling".
That said, when loops are simple enough, modern compilers will do a lot of loop unrolling for you, so you might not see much gain (in an optimized build, at least).
Thank you for your detailed responses. This forum is great for someone like me.
Respectfully,
David
David, I'm sure I speak for many of us that it's a great place for us too !
- Howard
