Hi does anyone know PLX DAQ label directive?
in Propeller 1
I modified PLX DAQ demo to calculate and send sin angles to EXCEL by using XBEEs instead of USB serial. However I am not getting labelling on XBEEs. I am getting correct labelling on USB serial: TIME, TIMER, ANGLE, SIN.
I checked PLX DAQ Object Library but I am not sure what is wrong?
{{ ***************** Simple PLX-DAQ Example ***************** Simple PLX-DAQ routine for data. Plots the sine of angle from 0 to 360 degrees. Program will send data on serial port to be accepted and placed into an Excel worksheet. This example also demonstrates reading the current ROW from Excel, and starting over again once it exceeds 300. Check "Reset on Connect" to catch configuration data. January, 2007 By Martin Hebel SelmaWare Solutions - www.selmaware.com Southern Illinois University Carbondale - www.siu.edu/~isat/est USE F11 WHEN DOWLOADING TO SAVE TO EEPROM AS PLX-DAQ WILL CYCLE DTR The PLX-DAQ Library must be created and started ┌────────────────────────────────────────────────┐ │ OBJ │ │ PDAQ : "PLX_DAQ" │ │ │ │ Pub Start | Angle, Row │ │ PDAQ.start(31,30,0,9600) ' Rx,Tx, Mode, Baud │ └────────────────────────────────────────────────┘ ***************** PLX-DAQ data structures used **************** PLX-DAQ directives used and how called: DATA Places data into the next row of Excel spreadsheet Up to 26 comma-separated values may be stored. Each value following "DATA," must be separated by comma-strings "," PLX-DAQ String: DATA,val1,val2,val3...Val26 PLX-DAQ String: DATA,TIME,TIMER, decimal value of X, Signed-Decimal value of X The Object library allows sending data as values or as text. When 1st called, if TimeStamp is enabled, "TIME,TIMER" will be sent before data is sent. A complete data set must end with a .CR call. ┌────────────────────────────────────────────────┐ │ PDAQ.Data(value1) ' Value │ │ PDAQ.DataDiv(Value2,1000) ' Value/1000 │ │ PDAQ.DataText(string("On")) │ │ PDAQ.CR │ └────────────────────────────────────────────────┘ TIME Replaced by PLX-DAQ with real system time (DATE may also be used) in DATA directive. Column cells should be formatted for time. ┌────────────────────────────────────────┐ │ PDAQ.Label(String("TIME,ext")) │ │ PDAQ.DataText(String("TIME")) │ └────────────────────────────────────────┘ When writing Data, if TimeStamp is enabled, "TIME,TIMER" will automatically be included when data is sent. It is true by default. ┌────────────────────────────────────────┐ │ PDAQ.TimeStamp(True) │ └────────────────────────────────────────┘ TIMER Replaced by PLX-DAQ with the seconds since last may also be used to show time since last RESETTIMER. Column should NOT be formatted for Time. ┌────────────────────────────────────────┐ │ PDAQ.Label(String("TIMER,ext")) │ │ PDAQ.DataText(String("TIMER")) │ └────────────────────────────────────────┘ When writing Data, if TimeStamp is enabled, "TIME,TIMER" will automatically be included when data is sent. It is true by default. ┌────────────────────────────────────────┐ │ PDAQ.TimeStamp(True) │ └────────────────────────────────────────┘ LABEL Places headings on the columns for rows A-J using up to 26 comma-separated labels. PLX-DAQ String: LABEL,label1,label2,...label10 ┌────────────────────────────────────────┐ │ PDAQ.Label(string("label1,label2,etc"))│ └────────────────────────────────────────┘ CLEARDATA Clears columns A-J, rows 2 and on. (labels remain). PLX-DAQ String: CLEARDATA ┌────────────────────────────────────────┐ │ PDAQ.ClearData │ └────────────────────────────────────────┘ RESETTIMER Resets the timer to 0. PLX-DAQ String: CLEARDATA ┌────────────────────────────────────────┐ │ PDAQ.ResetTimer │ └────────────────────────────────────────┘ ROW,GET Requests the last row data went into. PLX-DAQ String: ROW,GET ┌────────────────────────────────────────┐ │ Row := PDAQ.RowGet │ └────────────────────────────────────────┘ ROW,SET,val Sets the row the next data set will use. PLX-DAQ String: ROW,SET,2 ┌────────────────────────────────────────┐ │ PDAQ.RowSet(2) │ └────────────────────────────────────────┘ MSG Sets a text message in the PLX-DAQ control PLX-DAQ String: MSG,hello ┌────────────────────────────────────────────────┐ │ PDAQ.Msg(string("Hello")) │ └────────────────────────────────────────────────┘ ************************************************************** }} CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 CR = 13 OBJ PDAQ : "PLX-DAQ" Pub Start | Angle, Row PDAQ.start(2,1,0,9600) ' Rx,Tx, Mode, Baud PDAQ.Label(string("Time,Timer,X,SIN X")) ' Label the spreadsheet columns PDAQ.ClearData ' Clear present data PDAQ.ResetTimer ' Reset timer for seconds interval repeat repeat Angle from 0 to 359 ' Count from 0 to 359 PDAQ.DataText(string("TIME,TIMER")) ' Place current time and time since reset PDAQ.Data(Angle) ' Send data of angle PDAQ.DataDiv(Sin(Angle),1000) ' Send data of sin of angle / 1000 PDAQ.CR ' End of data for row Row:=PDAQ.RowGet ' Read current row If Row => 300 ' Greater than 300? PDAQ.RowSet(2) ' back to row 2 PDAQ.Msg(string("Restarting Data")) ' Post message to control Pause(100) ' 100mSec Pause PUB Sin(angle) ' SIN angle is 13-bit ; Returns a 16-bit signed value ' Code adapted from Parallax forums to use internal SIN tables Angle := (Angle * 1024)/45 Result := angle << 1 & $FFE if angle & $800 Result := word[$F000 - Result] else Result := word[$E000 + Result] if angle & $1000 -Result Result := (Result * 1000/65535) PUB Pause(mS) waitcnt(clkFreq/1000 * ms + cnt)
