Prop2 Interactive debugger - Page 4 — Parallax Forums
12467
    Rayman wrote: »
    Chip: "Absolute jumps can be forced by using \ before the address. "
    Is this new? I don't remember this...
    Is this only to within cog/lut?
    It must be still limited to +/- 256, right?
    It's been in the instructions.txt file, all along. For S-field immediate addresses, they are all relative (DJNZ, etc), and their range is -256..+255 instructions. In hub memory, they are left-shifted by two bits, since an instruction spans 4 byte addresses.
    David Betz wrote: »
    Why is the P2 interpreter so much bigger than the P1 interpreter that it can't fit in twice the space (COG+LUT)?
    It does a few more things, but not many, like instruction pointers, for example.
    jmg wrote: »
    Isn't the EXECF form more generally useful, for table jumps, and you do not have to use the SKIP mask there ?
    From a general language angle, I see SKIP as useful where you have many types (eg 8,16,32,64 fetches).
    Some languages have trended to one type, to simplify the user-end, but that comes at the cost of speed, and embedded usefulness.
    At the embedded end of the scale, there tend to be more types, and P2 surely targets mainly that end ?
    You could use EXECF for table jumps, but it would only jump from $000..$3FF in cog/LUT memory. If the upper bits were 0's, it would be just a jump instruction.
    To clarify SKIPF timing, every time 8 instructions in a row are skipped, one NOP executes.
    The only difference between v17 and my own current version is that SKIPF becomes SKIP during hub execution. This is probably not anything anyone wants to play with now, but when there's greater occasion for another release, the updated SKIPF behavior will be in there.
  • RaymanRayman Posts: 15,503
    edited 2017-03-31 22:53
    I read the .txt on absolute and "\", but I still don't get it...
    Does it mean jump to HUB instead of cog/lut?
  • Rayman wrote: »
    from the instructions_v17.txt file (and earlier versions too) that comes with FPGA files.
    For immediate-branch and LOC address operands, "#" is used before the
    address. In cases where there is an option between absolute and relative
    addressing, the assembler will choose absolute addressing when the branch
    crosses between cog and hub domains, or relative addressing when the
    branch stays in the same domain. Absolute addressing can be forced by
    following "#" with "\".
  • David Betz wrote: »
    My guess is because of smart pin support,cordic functions and other NEW built in stuff.
    edited 2017-03-31 23:27
    ctwardell wrote: »
    I'm mostly lurking now, have been for the past year or more due to time constraints of full-time work and my consulting business.
    That said, SKIP has made this very interesting again, it makes me want to make some time to get actively involved again.
    I understand the desire of some to just get it done, and acknowledge that my current lack of available time makes me more forgiving of any delays this may bring.
    I think we are very fortunate to have not only a ringside view to Chip's work on this project, but to also be able to be actively engaged and have input in the design. SPIN is an important part of the Propeller ecosystem and I understand Chip's desire to improve it's performance and features by making these changes. I also see SKIP being of benefit in many cases where fitting more functionality into a COG or even less space in HUB is important.
    We also need to keep in mind that we are watching this in real-time, comments about the designer not fully understanding their design seem to me to be a bit harsh. We get to watch Chip work out ideas, and even have a hand in testing and improving them, that's cool.
    Most, if not all of us, watching and participating don't have the time or resources to take on a project of this magnitude. I'm glad that Chip, Ken and the team at Parallax have been successful enough to take on this project and I appreciate being able to observe and take part in it.
    C.W.
    Making something that is fun and interesting to program, even at the lowest level, means improving the life of the people who use it. When you pick a technology to work with, it's like getting married, almost. If it has any lasting utility, you're going to become vested in it, so it should be worthwhile. I feel like much technology these days just gets uglier and more duplicitous, the more I use it, with me eventually realizing that I married a psycho - one that's like the wife of Schwarzenegger's character in Total Recall (she pretended to be his wife, but really worked for the evil Cohagen who ran the mining company).
    It's also often better when one person makes something...
    Teams are needed for huge things, but often the result isn't totally cohesive...
    edited 2017-03-31 23:19
    ozpropdev wrote: »
    I read that, but suddenly feel lost... There's a "JMP" and a "JMPREL" instruction.
    I guess the compiler usually turns a JMP into a JMPREL for me in cogexec?
    But, the plain JMP doesn't have an immediate option, just jumps to the address in the register specified by D, right?
    So, using "JMP #\somewhere" doesn't make any sense to me right now...
    Maybe it means it's going to insert an "ALTD somewhere" before the JMP?
    Can I use this to JMP more than 256 instructions away within a cog?
    Rayman wrote: »
    If you look at the 20-bit immediate instructions, there's an 'R' bit in them. That R bit is 0 for absolute, where the 20-bit field is used verbatim, or 1 for relative, where the 20-bit field is ADDED to the PC. This done was to allow code which used R=1 jumps internally to be relocatable within hub memory.
  • evanhevanh Posts: 16,642
    I remember this discussion has occurred before - because the Prop1, only having 512 executable space, uses absolute branching addresses.
    On the Prop2, for a loop that is larger than 256 longs, I'm guessing, since DJNZ is listed as relative branching only, that if a #\xxx is used then PNut will embed an AUGS in front of the DJNZ, correct?
    I also presume the faster loop execution would be to preload a sacrificial register with the relative 32-bit branch address.
    evanh wrote: »
    If you use ##address in DJNZ, it will assemble an AUGS, but it will still be a relative branch, just with a 20-bit relative address, instead of a 9-bit one.
    edited 2017-03-31 23:26
    deleted, mistake
    Rayman wrote: »
    There's also another immediate address only version of JMP down the bottom of the instructions.txt.
    edited 2017-03-31 23:43
    Okay it has to be relative. Would #\address in a DJNZ generate the exact same machine code by prefixing with an AUGS?
    Ok, I think I'm getting it now...
    You want to use relative where you can so you can move the code between cog/lug/hub
    Using absolute would break that...
    edited 2017-03-31 23:48
    FYI
    JMPREL can be used as a table jump instruction
    for example
    go		jmprel	cmd_index
    		jmp	#_run
    		jmp	#_cls
    		jmp	#_rep
    		jmp	#_rst
    		jmp	#_dis
    Rayman wrote: »
    Recompiling usually sorts such things. But there is now a bunch of branching instructions that are exclusively relative only - Chip just drummed that detail into me. So, PNut just uses relative by default.
  • That's right. Back at that time, we were unsure how much sense absolute would make.
    And relocatable definitely makes sense now, where on P1 it didn't matter.
  • jmgjmg Posts: 15,193
    Rayman wrote: »
    JMP does have a JMP ToAddressLabel option, which is used above, but the quirky PASM syntax is currently
    JMP #ToAddressLabel
    That is confusing, as what looks absolute (via the #) can assemble to relative/short...
    So yes it can be confusing to read, which is why I've suggested before that PASM gets a clean-up pass to make it more consistent with industry practice & remove clutter chars...
    In most MCUs you can code Assembler along these lines :
    Note absence of any #Label, or #/Label crypto-semantics. The word clearly indicates what you get.
    Label:
        JMP   Label  ;Auto-Assembles smallest jump, usually that's short/relative, but uses larger when needed
    ; often simpler 1-2 pass assemblers will use larger opcodes for forward jumps, because they do not know 'how far'
        AJMP   Label  ;forces Absolute jump
    ; and some also have
        FJMP   Label  ;forces Far Jump (largest opcode)
    ; or
        LJMP   Label  ;forces Far Jump (largest opcode)
    ; or
        SJMP   Label  ;forces short Jump (smallest opcode)
  • cgracey wrote: »
    Are you sure SKIP and its friends haven't turned P2 into one of these?
    David Betz wrote: »
    No, that's interrupts.
    FYI
    P2 SPIN uses a 32bit jump/skip table for each of the 256 bytecodes. This resides in LUT and uses half of the LUT.
    This is similar to what I did in the Faster Spin Interpreter in P1, except of course the table was in HUB.
    So this is where the cog/lut space is being used in P2 Spin.
  • evanh wrote: »
    Well, interrupts may be new to P2 but they aren't new to processor design. This SKIP instruction is. I suppose everyone here will claim that gives P2 a big advantage. I hope that's true. It just seems ugly to me. P1 was so clean and P2 seems to be going far in the opposite direction.
    edited 2017-03-31 23:54
    Ok, I think I'm back to having a handle on JMP.
    Few weeks ago, was thinking about DJNZ where there is no absolute option and had to put the far away (>256) address into a register to make it work...
    But now, I think I see that I could have "SUB it,#1 wz" followed by an "if_nz JMP #\somewhere".
    Either way wouldn't be relocatable to hub though, I think...
  • I see it as a systems type instruction. Drivers, really performance code.
    It won't need to be in general use.
    David Betz wrote: »
    I was just being cheeky, I haven't actually tried to get my head around SKIP at all.
  • potatohead wrote: »
    What happened to the claim that a big advantage to the Propeller is that it is possible to understand everything about it? I guess that excludes things like SKIP and interrupts when talking about P2. Those get buried in the opaque infrastructure just like the obscure hardware features of any other processor.
    edited 2017-04-01 00:06
    Nice piccys solves all. :P
    On the other hand, I was trying to make a graphic for the egg-beater the other day but gave up. It's as much a visual tangle as it is to imagine. It'll need an animation I suspect.
