Menu timout
Hello all,
I am working on a menu for a propeller project. But I am having trouble getting a menu timeout to work correctly. It will work sometimes, but then there are times where it will timeout way to fast. I have the timeout set for about 10-ish seconds. The timeout will reset when an encoder is turned. but there are times it will timeout in a second or less. Could someone please help me out with this problem? Here is what I am doing now. One thing the code cant do is pause (no "waitcnt").
TC
TC
var long TimeOut long MenuMaxTimeOut long EncoderValue long EncoderPos(2) OBJ encoder : "Quadrature_Encoder" PRI MenuMaxTimeOut := clkfreq * 10 - 3016 TimeOut := cnt repeat read_encoder "SOME CODE" if cnt > TimeOut + MenuMaxTimeOut "GOTO ANOTHER MENU SCREEN" PRI read_encoder | temp temp := EncoderValue + encoder.ReadDelta(0) if temp <> EncoderValue TimeOut := cnt EncoderValue := temp
Simpler to change the "repeat" to a "repeat until" or similar.
That was my first attempt, but the menus have different things in them. So one menu would be the correct time, while others would be a lot faster. That is when I thought of keeping track of the "cnt" counter. That way, no matter how long or short the menu is, the timeout would be about the same.
I usually test it with a small range.
Consider your cnt can span from -3 to +3
menumaxtimeout is 3
cnt rolls over (after 3 it becomes -3 and starts over)
If timeout is 2 adding menumaxtimeout you get -2
you check if cnt > -2, and if you just read timeout you are +3 and you get the shorter timeout
If you test the difference, cnt is +3 and timeout is +2, cnt - timeout = 1 so the test fails.
If cnt is -3 (roll over) cnt - timeout is 2 so you avoid the rollover trap.
Not sure if it is clear..
Massimo
The "SOME CODE" is writing all the text to the display, monitor the encoder select button, and change the screen to match what the encoder is doing. Like highlighting "YES", "NO", "MAYBE", etc... with every click of the encoder. I did not want to post the full code since there is a lot there.
The only thing I like about the Arduino is the millis() function -- this does the same thing except that millis is a global variable and you can change it from any cog that knows where millis is.
When the encoder changes, do this:
To check for a time-out:
If you don't want to disturb millis you can using like the cnt register:
then...
You can do a lot of work in 1ms. I have a background cog that runs millis, a game timer, reads two shift-registers, plays monotonic music, and debounces a couple of direct inputs -- and I still have time leftover. You'll want to make a bigger stack when you start adding more "background" processes.
In JonnyMac's code suggestion (see above), the MS_001 constant should/can be defined as:
