DENON AVR-788 RED LIGHT OF DEATH
Have the red light of death on my Denon AV 788 Surround sound receiver.
Went to Youtube and saw a number of people who had success by changing out the Power Supply Board Linear Voltage Regulators.
I purchased 4 new regulators from Mouser Electronics; each were the correct part numbers.
I did a bench check of the old regulators and found that the old 7508A was at 605 & 1601 in diode mode, so I figured that was the bad regulator.
The new regulator read 619 & 676 (Connecting the positive to the center terminal & negative at each end). After replacing the new part, I still got the Red Light of Death. I plan on changing out the other three regulators just to see if it may solve the problem. Short of mailing the unit out to a shop, is there any advice on what could be the culprit?
Thanks for any constructive input!
Bucko
Bucko
I think bad caps is a common problem with audio equipment.
In fact, just having a working unit on the bench next to yours can help you troubleshoot your problem and zero in on a fix. Compare readings to localize the fault, fix yours, then keep or sell the second unit.
My very first electronics repair job many moons ago was fixing a Pioneer SX-550 receiver, one channel was dead. I knew nothing about electronics but I dove in with a multimeter, comparing the good & bad channels to isolate the fault. Swapped out a $1 transistor and that receiver still works well today.
Nice story.
From that day forward, your future was set in stone
I love the smell of solder in the morning. Bacon is a close second.
I have had a Pioneer SX-850 on a shelf for years, bad channel. Haven't been into audio for a long while because of small animals in the house. Like it loud!
EDIT: Sorry but I have to take screenshots of my pictures so the size is ok for upload.
http://classicreceivers.com/pioneer-sx-1250
Best combo ever made.
The 1250 was the monster. Buddy of mine got that one, they sure made the 70s ROCK!. What speakers did you you get for that. I think I bought the biggest they had:
EDIT: I remember now, they were the smallest in the HPM series that had walnut veneer cabinet. The HPM-60 had some kind of vinyl covered compressed wood, if I remember right.
Then I got some Altec-Lansing Voice of the Theater from the band that I did sound for.
http://www.audioheritage.org/html/profiles/altec/vott.htm
The A5X. That Pioneer would drive the heck out of them.
But we are derailing this thread, although it has nothing to do with Parallax. I may have to sink it.
My grills still look pretty good to, sometimes hard to do, when they're involved in a move or two along the way.
Wait, how can I hook up a Propeller to control my audio receiver?
Phew, that was close!
Actually I just liked the "red light of death" phrase. Hoped it was lasers on sharks or thereabouts.
Did you actually measure voltages before buying parts?
I have the RS Mach Ones too! Replaced the foam surrounds on the 15" speakers quite a few years ago.
The cabinets still look new - used a Wipe-On polyurethane.
Crank them up and they will blow out match...
I had a Sony receiver that starting giving me fits - the back channels would cut out. Reseated some connectors and it would work for a while then mess up again.
After some more issues, I junked it and bought a Yamaha RX-V481BL - really pleased with it!
Hadn't thought to try that! This VC looks like fun too, whether extinguishing fire or igniting fire rings.
