VGA Game/Demo for PropBOE anywhere?
laurent974
in Propeller 1
I just received my Prop Board of education.
Is there any small VGA games that could be played out of the box?
http://forums.parallax.com/discussion/113827/prop-chess-for-vga-human-vs-propeller
I 'll read the code and i'll try to change it to send keyboard command througth the serial console
see his thread here :
Tile Graphics Renderer
instead of a nes_pad i used a memsic 2125 dualaxis at pin 6 and 7 (you can change it inside the controller.c) and 2 push buttons at pin 0 and 1
The VGA pin starts at pin 8.
Very cool!
Thanks to you both.
Here is space invaders with the same pins configuration as above.
memsic 2125 dualaxis at pin 6 and 7 (you can change it inside the main file) and 2 push buttons at pin 0 and 1
original code is here : http://forums.parallax.com/discussion/116037
