Converting HYDRA specific programs to other boards
Oldbitcollector (Jeff)
This thread is started for those that are considering buying the HYDRA or just the HYDRA book, this thread will give hints how to convert programs that are on the hydra CD and in the text to make sure they work on other propeller based boards.
Some guidelines:
If you are posting a how-to conversion of HydraCD programs, please do not post the entire .spin code as these are copyrighted works. Instead post the 2-5 lines that need to be addressed, or areas where code needs to be added.
This would be a good thread to discuss the differences in pin configuration between Hydra and other propeller products.
Thanks to Andre for encouraging this thread and discussion.
Oldbitcollector
"Two things are infinite: the universe and human stupidity; and I'm not sure about the universe." -Albert Einstein
Some guidelines:
Oldbitcollector
(These are before the discussion of the HEL driver)
They can be altered slightly to make them run on other propeller-based boards.
Make the following changes: (Example /sources/hydra/screen_saver_10)
Near the top of the file: [noparse][[/noparse]clock settings]
Change:
to
Now, look a little further in OBJ section.
(Use the graphics.spin & tv.spin from the Propeller Library)
Change
to
Now scroll down the nealy the bottom of the file and look for this:
(Change video pins)
Change:
tvparams long 0 'status long 1 'enable long %011_0000 'pinsto
tvparams long 0 'status long 1 'enable long %001_0101 'pinsThese changes can be done to several of the demos in the introduction to the "graphics" driver
If you want to play with the HEL_GFX_ENGINE* files, I've found the following changes get things up and running,
and makes the /sources/hydra/pacman_tile_demo* a lot more interesting. [noparse]:)[/noparse]
Open HEL_GFX_ENGINE_040 (Used in /sources/hydra/pacman_tile_demo_005)
Find in the CON section
Change it to:
Find (near the bottom) (Thank you Andre!)
Change it to:
(Proof that a million monkeys with a million propeller chips *could* write Shakespeare!)
The comments and code above are proof that a million monkeys with a million propeller chips *could* write Shakespeare!
Post Edited (Oldbitcollector) : 4/19/2007 2:31:15 AM GMT
I find the DEMO board more instructive at the moment and it is wonderful that all those
HYDRA programs can be ported over -- or at least many of them.
I have a problem with the HEL conversion listed, the suggested change of VIDEO_SETUP
to a new value has 9 bits instead of 8 -- discovered after I tried running it.· Could be
the problem???
Fred2
I've correctly the entry, and it *should* work correctly now. <fingers-crossed>
Oldbitcollector
clean crisp multicolor sprites as well as music. I have this running using my Atari Joystick (on the VGA header) but I'm still working on cleaning up my joystick code. Anyway, here are some simple changes to get the graphics & sound up and running.
/sources/hydra/JTC_Xracer_010
Inital changes are very much like the first demo in this thread...
Change the clock settings to:
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000and the tvparms (pins) to (near the bottom of JTC_Xracer_010.spin)
tvparams long 0 'status long 1 'enable long %001_0101 'pinsFor sound look for the following:
and change the 7 to a 10
This should get it up and on the screen. More later on controls..
Oldbitcollector
of course but it is neat just showing the static scene!
Had to do some searching through the code, but it is a fabulous program -- could be studied
for weeks....
fred2
Andre'
One bit thing that the Hydra has over us Demo/Proto users is those nice NES ports built in.
Here's our chance to "come up to the Jones"
This file contains a drop-in snippet of code for those Hydra demos which use a PUB section
for reading the NES controls as well as a replacement gamepad_drv_001 for those that call
on it.
I've tested the snippet on the Xracer demo, the fire button alternates between START/SELECT
so it works with the button limitation. The additional gamepad_drv_001 has been tested with
the pacman tile demo and seems to work perfectly.
It's a little building, but for less than $10 worth of parts, in an hour you'll have game controls.
Let me know about bugs when you find them. [noparse]:)[/noparse]
Oldbitcollector
Post Edited (Oldbitcollector) : 4/20/2007 5:11:27 AM GMT
/sources/hydra/RB_Tetis_010.spin
There are several things to do here, so take your time and knock them out one by one.
First as always, convert the clock settings in CON to:
Drop down to OBJ and adjust them to use the Propeller Library items, as well as Mike Green's comboKeyboard Driver.
Next dig out the key.start(3) and change it to: (It's in PUB start)
[noparse][[/noparse]Note the remerked mouse driver Hmm..]
Just when I thought I had Andre figured out on the NES controller thing,
I discover some of the code was only written for a single NES controller.
No worries, this one works fine.
Here's a replacement PUB that works well..
PUB NES_Read_Gamepad : nes_bits | i 'This is intended as a replacement for code which contain 'an embedded NES_Read_Gamepad function. Simple overwrite 'the entire 'PUB NES_Read_Gamepad' with the contents of this file. 'Adjust remarked entries as required. 'This is designed for the adapter: 'atari_vga_schematic.jpg" if ina[noparse][[/noparse]16] == 1 'Read Fire alternate between Select & Start nes_bits := %00010000 if ina[noparse][[/noparse]17] == 1 'Read RIGHT show as NES_DPAD Right nes_bits := %00000001 if ina[noparse][[/noparse]19] == 1 'Read LEFT show as NES0_DPAD Left nes_bits := %00000010 ' if ina[noparse][[/noparse]21] == 1 'Read DOWN show as NES0_B button ' nes_bits := %01000000 if ina[noparse][[/noparse]21] == 1 'Read Down show as NES0_DPAD down nes_bits := %00000100 if ina[noparse][[/noparse]23] == 1 'Read UP show as NES0_A button nes_bits := %10000000 ' if ina[noparse][[/noparse]23] == 1 'Read UP show as NES0_DPAD up ' nes_bits := %00001000 nes_bits := (nes_bits & $FFFF)One more thing to change, tvparms...
tvparams long 0 'status long 1 'enable long %001_0101 'pins long %0000 'mode long 0 'screen long 0 'colors long x_tiles 'hc long y_tiles 'vc long 10 'hx timing stretch long 1 'vx long 0 'ho long 0 'vo long 0 'broadcast on channel 2 VHF, each channel is 6 MHZ above the previous long 0 'auralcogControls, joystick L/R to select level, button to start. L/R, UP=rotate, DOWN
There is keyboard and sound support, but for some reason I haven't gotten them right yet.,. more later
Oldbitcollector
Post Edited (Oldbitcollector) : 4/20/2007 6:19:40 AM GMT
Ok, so you didn't build yourself an Atari Joystick Adapter yet.. Here's some additional code to get the keyboard working.
Look for this section:
' Keyboard (mapped onto NES buttons) if(key.keystate($C2)) nes_buttons|=NES_UP if(key.keystate($C3)) nes_buttons|=NES_DOWN if(key.keystate($C0)) nes_buttons|=NES_LEFT if(key.keystate($C1)) nes_buttons|=NES_RIGHTAdd the following two controls...
if(key.keystate($0D)) nes_buttons|=NES_START if(key.keystate($20)) nes_buttons|=NES_ARight/Left Cursor = Select Level, Enter to start, SPACE to rotate.
Enjoy
Oldbitcollector
Jim
it's sad because these source codes are really a marvel to read, but no more hardware supports that.
