Basic Stamp 2 voltages
in BASIC Stamp
what is the difference between VDD and VIN?
Flasher
Flasher
Vin is the input for higher voltages, typically 6-9 volts. The onboard 5V regulator reduces that voltage down to 5.0V for the BS2. That same 5.0V will show up on the Vdd pin, so you may draw a bit of power off that pin to power some external circuitry if you need to.
Vss is ground, or zero volts, connected to the battery minus terminal.
And then there's Vcc used in some conventions...!
I finally finished the in-line switch installation. When I say installation, it sounds like a major endeavor; for me, it was! It was like trying to thread a needle while somebody is shaking your rocker. I didn't know they made nuts and bolts that small.
Oh-by-the-way, a few years ago, a large department store( Roses) closed in town and I found a bunch of RC cars and bought 7 of them for $5 each. I have had a lot of fun with them, tearing them apart and using the little transceiver to control other projects. The receiver has 13 transistors! I was not able to find out what part of China they were made in.
73s
