Need to find, lost.
in Propeller 1
I had to go over to a backup SD Card on my Raspberry Pi, and I do not have the links for OpenSpin and PropLoader (either the precompiled RPi versions or the source versions). So links would be of help.
Also is there a way to get the Propeller Font working with ARM Linux? I do NOT use the PropellerIDE, I use either xedit or leafpad to edit source, and a terminal to compile and load.
https://github.com/parallaxinc/OpenSpin
Download a Raspi executable or build from source easily enough.
PropLoader is here:
https://github.com/parallaxinc/PropLoader
No idea about Propeller Font. It's a bad idea anyway.
Full list of projects on TeamCity here: http://david.zemon.name:8111?guest=1
I have no idea about the Propeller font either, sorry.
