My WIFI ESP8266 has Disappeared from my Network
in Propeller 1
Is there a master reset on this thing to return it to the original factory state? It has disappeared from my network and now I can see it. This is the second one of these I have bought because of this. I thought I had damaged the first one but my gut feeling is it is just a a setting. I wish I could just reset it. I cant find a trouble shooting section in the manual or any information about what to do if this happens.
Is this a sip or dip btw? You could hook a propplug onto the sip pins/pads if you have one.
If you can get that far, I could post a reset script for you. Just need a bit of time to document it.
I do have a prop plug.
I put a ESP8266 on a Sumobot, and found that if I connected a servo to either GPIO0 or GPIO2 then it stopped functioning as expected until the servos were disconnected.
In the meantime I'll go get the reset procedure. Should be tonight.
I can run a wire to the ground and to my five volt power supply header on my Board of Education and power it up but it doesn't show up on my network now. It did before. I'm about to blow a fuse myself over this thing. I have bought two of these wifi modules back to back and not having any luck.
- and good sleuthing DB!
