DB9 serial cable wiring
jknightandkarr
in Accessories
What is the wiring for the DB9 serial cable? I found this image, but not sure if its right.
I think my serial cable is bad, cause I have a Basic Stamp 2 Homework, PDB Rev B & the Propeller RPM Black modual all of which have serial ports and none of which are ever found, and tried 2 different pc's so its not the serial port, so I wanna make a test cable to see if thats the issue. Thanks
Joe
Joe
Joe
Original XP HyperTerminal
If you just can’t live without the original HyperTerminal in Windows XP, you can actually extract two files from your XP installation and copy them over to Windows 7 or Vista.
The two files you will need are hypertrm.dll and hypertrm.exe. Simply copy those files into any directory on your machine and it will work. You should be able to find hypertrm.exe in C:\Program Files\Windows NT and hypertrm.dll in C:\Windows\System32.
If you have the Windows XP CD, you should be able to find both of these files in the i386 directory on the CD.
Joe
Joe
When using the basic stamp2 use a straight thru cable. Pin 2 should go to pin 2 and pin 3 to 3.
The stamp2 itself does of course have no DB9 (actually DE9, but that's nitpicking) connector, rather the development boards do (homework, board of education, more?)
It's actually surprisingly difficult to find on Parallax' website, but eventually I found: https://www.parallax.com/product/800-00003 , which is mentioned in https://www.parallax.com/sites/default/files/downloads/28158-BASIC-Stamp-HomeWork-Board-Documentation.pdf
I found the cable, I might need to just buy a new one, Kinda sucks having boards and can't use em...
Joe
