QS Rev.A programming through header
in Propeller 1
Hello All,
Is there any workaround to be able to program the Rev. A quickstart through the 40 pin header? I am trying to use my wifi module for wireless programming but it doesn't work as it should. I soldered a lead from the DTR pin on the module and hooked it to the RESn pin on the quickstart and that portion seems to be working fine. I believe the problem lies with the QS board pulling the RX pin low.
Bryan
Bryan
There is nothing that should not be anything on the board that would hold it low like that, I just took a good look at both the Rev A schematics, and the PCB layers for the Rev A, nothing on the board should be holding either the TX or RX low. As to the RESn (reset) that I am not sure of, as I can not find anything connected other than the header, where there should be a connection for programming through USB.
So I can not find anything in the design to cause an issue. If you wire a normal prop plug into the header what results do you get when attempting to program the on board prop through the prop plug?
If you power the Quickstart over he VIN pin with 5V and leave the USB unconnected U4 may be tristated (but not for sure because the Vcc of U4 is missing then).
Andy
