LiPo battery charging station -
As we require bigger and bigger batteries - charging them becomes an increasingly risky proposition.
For your consideration - here's a charging station that might mitigate the risk involved.
A steel drum and some concrete blocks. The block goes in the bottom of the drum, the battery goes inside the block. A piece of metal window screen goes over the top of the drum
In the event of an explosion the drum contains the fire - and the screen stops the flames.
Thoughts?
Anyone have the equipment to test this concept? This would make a good youtube video.
Thoughts?
I use ammo boxes, with lipo bags of questionable quality inside. 1 battery per bag, 2 bags per box. I hope I never have to find out if they don't work.
I would love to do some lipo fire testing, but I'd have to drive 2 hours to the desert.
Controlled explosions in the city are frowned upon these days, some of the stuff I done as a kid with BP or match heads would get more than a few neighbor's attention.
Bottom line is you really can't be too careful. Safe storage and safe flying, for everyone!
I read about a longtime RC shop owner - who apparently had a long history with LiPo batteries. He had a batch charging for a meet - left the shop for just a few minutes - came back to a burnt down business.
With the barrel, block, screen combination - I was looking for a way to charge inside my shop - but even that may be unrealistic.
Yes, I know that properly handled there is a small risk - but you can't throw a blanket on a LiPo out of control - at that point the ship has sailed.
It looks like Parallax only sells a small one but there are all sorts of sizes available online.
There are videos showing how well these things contain the flames. I've heard LiPo cells really stink when they burn. I keep intending to move my charging station from the basement into the garage so if there's ever a fire the smoke won't stink up the house.
Here's a link to a video testing one of these bags with a small(ish) battery.
I think it's hard to bet these sorts of bags for containing possible flames from a charging LiPo pack.
Edit: FWIW, I use a bag like the one shown above when I charge my LiPo packs.
Here's the you tube I found about this.
Looks like a good choice is an ammo box without sealing the lid - but even that probably has it's limits.
One way or the other none of these tests look like something my wife would forgive me for if it happened in the house...even if it didn't burn the house down.
should I be worried :S
My guess (and it's only a guess from the videos on you tube) is that the Li-Po bags are sufficient for smaller batteries.
Longer answer -
But even then - if the bag is on your desk or workbench - and lets loose, you'll probably have a mess to clean up.
Larger batteries letting loose (no definition of 'larger') will be an exponentially larger mess.
Battery design that pushes the limits of size (Samsung cellphone problems) or isn't manufactured to high quality standards present the greatest risk. The Samsung batteries have blown up without warning.
I haven't seen any indication that there is a standards organization (such as UL) putting their stamp of approval on LiPo batteries. We all live in a cocoon with incredibly dangerous energy within hands reach - but standards and engineering make it safe. LiPo battery technology appears to have outrun those organizations.
The charger is a critical piece of the problem - if it doesn't stop automatically - the battery is going to overheat and explode - that much seems to be a given.
Does anyone know if there is a difference between Li-Po and Li-ion, as far as charging and fire hazards are concerned.
I have been using the MCP73863 chip as my charger. The datasheet says it works for both.
I limit the charge rate to ~1/2C, and the cut off voltage to 4.1, to extend battery life. I'm hoping this also lowers the risk.
sleepless in Wisconsin :0
From what I've read, a Li-Ion cell is a LiPo in a can. I think the can reduces the fire danger a bit.
