Losing the touch - how to modify LED light fixture to bypass touch on/off
Erlend
I've bought a led lighting fixture to have above the kitchen bench (one of several). It is a LED strip and fits the purpose perfectly - if it was not for the touch toggle on/off function on every fixture. I want one, central switch for all of them. Looking inside I found BC83B08A-3 MCU which handles the touch signal, and a 4406a GA5N2P which I assume is some sort of constant current regulator. There are more circuits, but I believe these two hold the key. Problem is, it is very difficult to identify the pcb tracks, and secondly, I can not find a datasheet for the 4406a GA5N2P. I think the BC83B08A-3 is outputting a PWM, but since it would be 100% when on, I am thinking I can just tie this signal high. But this is too much guesswork for the cost of a potentially burned fixture. Anyone done this before?
Erlend
Erlend
Depends on how much of a problem that is. Also need to test for typical power situations like long and brief outages, on/off flickering, and solid off to on switching. If signal timing is critical that could be solved with a 555 timer. One way to find out is to try it with multiple units.
If the 4406a GA5N2P is a constant current regulator (which seems likely as searching had it mentioned as a battery charge chip) then perhaps the signal from the BC83B08A-3 could be replaced with a switch.
Erlend
If step one gives a consistent off or on you can connect a wire from a switch or 555 to the "touch" area and see if that works. If a DC signal works you are good to go. If it requires an AC signal you may need a 555 or 556 to produce the signal.
Of course there are plenty of other things I should instead spend my weekend on, but if you're a tinker...
Erlend
BTW: Your picture "LED_fix.jpg" failed to load.
Jumper from pin 8 to pin 10.
Erlend
