Quick WiFi Question
in Propeller 1
I bought a Board of Education in December and bought the WiFi module(SIP version). I have no luck programming with it. I just purchased a new WiFi module(DIP version). Will this work with my Board of Education? Do I just need to get the activity board or are the WiFi modules compatible with both boards? Can I simply drop it in the Xbee slot for either board and it work?
TX to DI
RX to DO
RESET to DTR
GND to GND
I am OK with using my mini instead and just sending information pin to pin between the two.
I just wanted to double check that this scenario should work for programming the mini wirelessly?
So far I'm not getting it. I have tried it using the prop plug pins 31,30 pins and tried it using pins 9 and 8 as it mentions in the tutorials.
The project builds but fails to load it into the mini.
I have been reading through as many of the forums as I can. Some posts say wireless programming can only be done with the Activity Board WX, others seem to say that you can program wirelessly as long as you connect a jumper from reset to DTR pin 18 on your WX module.
The firmware that supports RTS in the SIP header is not available on the Parallax site yet.
From what I remember reading in other forum posts the DIP and SIP modules are technically identical just that they ship with different connector pins. Is that correct?
Right now I have the WiFi module SIP connectors connected as follows
SIP
Pin 1 Vin to 3.3v on the Propeller mini
Pin 7 DO to the RX on thePropeller mini prop connector
Pin 8 DI To the TX on the Propeller mini prop connector
Pin 10 to GND on the Propeller mini
I then have a wire soldered onto pin 18 on the DIP headers connected to the propeller mini RST
I have also tried connecting
Pin 7 DO to pin 9 on the Propeller mini
Pin 8 DI to pin 8 on the Propeller mini
Per the training examples
No luck so far.
I have not yet tried connecting to the DIP pins 2 or 3 for DO DI but figured they would be the same as DO and DI on the SIP connectors.
That is correct.
And don't forget Andy's post:
RST is available on J3.
EDIT: I saw you soldered a wire to RST.
I was hooking up RX and TX backwards. I didn't realize the RX printed on the Mini's Prop Plug connection was actually the Mini's TX port.
Able to load programs and run with terminal wirelessly!
