Servo Upgrade
I am upgrading my robot with the some high torque servos for a specific application.
http://www.savoxusa.com/Savox_SC0251MG_Digital_Servo_p/savsc0251mg.htm
I have tried to alter my servo.spin files to drive these servos however I have had no luck. Could somebody please look at my servo.spin file text below and help me make the modification based on my new servos information from the link above? I removed the assembly language section here just to get it to fit here.
* Servo32v7 Driver v7 *
* Author: Beau Schwabe *
* Copyright (c) 2009 Parallax *
* See end of file for terms of use. *
Control up to 32-Servos Version 7 08-18-2009
Coded by Beau Schwabe (Parallax).
History:
Version 1 - initial concept
Version 2 - (03-08-2006) Beta release
Version 3 - (11-04-2007) Improved servo resolution to 1uS
Version 4 - (05-03-2009) Ability to disable a servo channel
and remove channel preset requirement
Version 5 - (05-08-2009) Added ramping ability
Version 6 - (07-18-2009) Fixed slight timing skew in ZoneLoop and
fixed overhead timing latency in ZoneCore
Version 7 - (08-18-2009) Fixed servo jitter in ramping function when
servo reached it's target position.
Theory of Operation:
Each servo requires a pulse that varies from 1mS to 2mS with a period of 20mS.
To prevent a current surge nightmare, I have broken the 20mS period into four
groups or Zones of 8 servos each with a period of 5mS. What this does, is to
ensure that at any given moment in time, a maximum of only 8 servos are receiving
a pulse.
Zone1 Zone2 Zone3 Zone4 In Zone1, servo pins 0- 7 are active
In Zone2, servo pins 8-15 are active
│─5mS│─5mS│─5mS│─5mS│ In Zone3, servo pins 16-23 are active
│─────────20mS──────────│ In Zone4, servo pins 24-31 are active
1-2mS servo pulse
The preferred circuit of choice is to place a 4.7K resistor on each signal input
to the servo. If long leads are used, place a 1000uF cap at the servo power
connector. Servo's seem to be happy with a 5V supply receiving a 3.3V signal.
CON
_1uS = 1_000_000 / 1 'Divisor for 1 uS
ZonePeriod = 5_000 '5mS (1/4th of typical servo period of 20mS)
NoGlitchWindow = 3_000 '3mS Glitch prevention window (set value larger than maximum servo width of 2.5mS)
'Use at least 500uS for overhead (actual overhead about 300uS)
LowRange = 500 '<- during Debug I changed this value to 1 to test 1us resolution
HighRange = 2500
VAR
long RampFlag
long ZoneClocks
long NoGlitch
long ServoPinDirection
long ServoData[32] '0-31 Current Servo Value
long ServoTarget[32] '0-31 Desired Servo Value
long ServoDelay[32] '0-31 Servo Ramp Delay
byte lpin,rpin
pub setpercent(pin,ppos)
'position given in 0..100
set(pin,ppos*12+900) 'from .9..2.1ms
PUB Start
ZoneClocks := (clkfreq / _1uS * ZonePeriod) 'calculate # of clocks per ZonePeriod
NoGlitch := $FFFF_FFFF-(clkfreq / _1uS * NoGlitchWindow) 'calculate # of clocks for GlitchFree servos. Problem occurs when 'cnt' value rollover is less than the servo's pulse width.
cognew(@ServoStart,@ZoneClocks)
pub getServoData
RampFlag:=1
return @ServoData
PUB Set(Pin, Width)|S_Width 'Set Servo value
S_Width := LowRange #> Width <# HighRange 'limit Width value
Pin := 0 #> Pin <# 31 'limit Pin value between 0 and 31
ServoData[Pin] := ((clkfreq / _1uS * S_Width)/620)*620
ServoTarget[Pin] := ServoData[Pin]
if S_Width==Width
dira[Pin] := 1 'set selected servo pin as an OUTPUT
else
dira[Pin] := 0 'set selected servo pin as an INPUT only if Width out of range
ServoPinDirection := dira 'Read I/O state of ALL pins
DAT
I've added code tags for you around your code sample. Makes things much easier to read for members to help you.
You can use code tags anytime you post code.... It's not so obvious, but the "C" button in the text-formatting panel will insert the tags for you.
Have fun!
What is the code that is using this driver?
I calculate the zone period to be (1/1520)*1000*1000*(1/4) = 164. The parallax servo is at 5000 micro seconds or 5 milli seconds. Does this look correct? The no glitchwindo for the new servo will be roughly 100 and low and high range will be 4000 and 5000
Are you sure it's not the IO pin voltage? Maybe the servo needs a little more signal than 3.3v?
I have a Propeller Board of Education with the servo pin set to Vin. It is being powered with a 11.1 volt 3000mAh battery.
https://www.parallax.com/sites/default/files/downloads/32900-Propeller-BOE-Documentation-v1.1_0.pdf
Servo running current ~325mA. This seems like it should work.
Servo voltage should be 6 volts max, requiring up to 2.5 A. That's probably too much for a Board of Education. How many of these are you driving, and what are they doing?
The servo's signal wire is usually 5 V logic level, most servos are okay with a 3.3 V, though.
I've burned out servos with a two cell LiPo. I think it's unlikely your servo survived being connected to a three cell LiPo. A fully charged 3-S LiPo pack can have an output of over 12.6V. Most servos are limited to 6V power supplies.
I agree with xanadu on this. I think the original servo code should work fine with those servos.
I did however get my wires crossed with my PING and fried it instead.
If I had gone to your first link and hit Technical Specs, I would have seen:
That would have thrown up a flag and saved you some time.
Glad you back up and running.
There seems to be a rash of this lately, we need to slow down and double check connections before applying power. There should be a catchy phrase like the people in carpentry have: "Measure twice, cut once".
How about: "Check twice, burn none".
I do this a lot, given two jumper wires the same color, I will hook them up wrong the first time if i'm in a hurry. Double checking has saved my electronics more than once.
Bad habit.
Enjoy!
