How do you disable the crystal on the Quickstart?
I have a Quickstart board that will flash LED's but it won't communicate with the Parallax serial terminal. I want to replace the on board smt crystal with a through hole one.
The Quickstart layout PDF calls R13 a shunt which, if removed, will allow you to use a through hole crystal. Can I just snip it off?
It is very unusual for a crystal to fail. It sound like the PLL on the propeller chip might have gotten damaged.
Personally, I think I destroyed my crystal when I desoldered it. While I have a desoldering iron, copper braid and a desoldering pump I need practice.
I think I'll find something to practice on.
Salvaging parts from circuit boards in outdated electronics is good practice. A little more solder and some persuasion, or the vacuum + braid and some persuasion. It is the combination that works, as long as the heat isn't to high. A propane torch is useful on components with numerous pins. It is an art.
Parallax boards are heavy duty, it would take alot of abuse to pull the print, especially on through hole.
setting the clock frequency in a child object in a new cog hoping that the problem was limited to cog zero.
I could only get it up to 19,200 baud before I got garbage on the serial terminal.
Oh well, I guess it's still usable. I can still find something to use it for. :frown:
