Propeller reset — Parallax Forums
Propeller reset
What transition resets a Propeller chip? Is it the transition from low to high on the /Reset pin? I'm asking because I'm wondering what would happen if a Propeller is powered up with its /Reset pin held low and then later it is brought high. Would the Propeller come out of reset and start its boot process? Or does that require both the transition from high to low and then low back to high?
  • The Prop's reset is not edge-sensitive; it's level-sensitive: i.e. any low that meets the hold time requirement.
  • Okay, so no matter what the initial state of /Reset, if I hold it low for say 10ms and then bring it back high then the Propeller should reset. Is that correct?
    Yes. It will then start 50mS after RESn is brought high.
  • Thanks!
  • jmgjmg Posts: 15,199
    David Betz wrote: »
    Most static CMOS parts have Level Sensitive Reset, which means you can hold RST low during Power Up.
    Many MCUs also have a reset width spec, in SysCLKs, - ie they need a CLK active, in order for that Reset to occur.
    In those, holding reset low, then raising before the clock starts, gives no reset.
    There is also a reset active Icc, that matters in power-wakeup designs, but often is not specified. ie the Icc drawn during a long-term reset.
    (In P1 there is also the power drawn, during the long reset-exit)
    P1 has an on-chip RC osc as the default driver, so it should meet any SysCLK during reset needs that may be present.
    edited 2017-02-12 20:51
    To clarify, the boot loader starts loading into RAM from ROM 50ms after /RST goes high. That process takes 640us. Loading code from EEPROM into RAM to start executing takes another 1.3-1.6s.
    The Propeller datasheet does not specify a minimum hold time for /RST, nor does it specify a maximum glitch length on Vdd before a brownout reset occurs. The latter is probably also a function of the glitch's "depth" and the effects of the chip's internal capacitance.
