BS2 servos do not turn the opposite way
trelozakinthinos
in BASIC Stamp
Hello,
First post here!
I am from Greece and I have collected DeAgostini's robot which has Parallax'es BS2. I am trying to rotate the robot where the light is. This is accomplished with 2 photoresistor one for left and one for right in combination with resistor and capacitor.
This is my programm
There is a problem with the turn_left command. It just turns so slow that is like shaking.
I tried in a new program to try it and it worked perfectly.
Any ideas? Thank you for your time!
First post here!
This is my programm
' {$STAMP BS2}
' {$PBASIC 2.0}
'----------variables------------------
photo_right VAR Word
photo_left VAR Word
pbin VAR IN2
'------constants---------------
threshold CON 20
left_in CON 10
right_in CON 9
left_servo CON 12
right_servo CON 13
'---------------activation-------------------
LOW right_servo
LOW left_servo
start:
IF pbin = 1 THEN start
'---------main--------------
main:
HIGH right_in
PAUSE 3
RCTIME right_in, 1, photo_right
HIGH left_in
PAUSE 3
RCTIME left_in, 1, photo_left
IF ABS(photo_right-photo_left) < threshold THEN main
IF photo_left > photo_right THEN turn_right
IF photo_left < photo_right THEN turn_left
turn_left:
PULSOUT right_servo,500
PULSOUT left_servo,500
PAUSE 20
turn_right:
PULSOUT right_servo,1000
PULSOUT left_servo,1000
PAUSE 20
GOTO main
' {$STAMP BS2}
' {$PBASIC 2.0}
lowtime VAR Word
lowtime=20
LOW 12
LOW 13
loop:
PULSOUT 12,500
PULSOUT 13,500
PAUSE lowtime
GOTO loop
I forgot the GOTO main under the turn_left!
(for instance if photo_left = photo_right)
Yes you are right! Thank you.
Even the possibilities to be equal are very low it is more safe to add it!
