GitLab.com in trouble
Anyone using GitLab.com's issue tracker or merge requests? GitLab.com accidentally wiped production data... ouch!
Twitter account announcing the problem: https://twitter.com/gitlabstatus
Tweet announcing the problem:
Google Doc explaining the problem in detail: https://docs.google.com/document/d/1GCK53YDcBWQveod9kfzW-VCxIABGiryG7_z_6jHdVik/pub
It's like plane crashes... It is never just one problem, but a series of problems all leading to disaster.
This is classic. Unless you verify that backups are working, then you need to assume that they are broken. e.g. don't just make a tape and take it off-site. Try to restore a system with that tape, and verify the completeness. Being in charge of this sort of thing can be tedious and boring, but that can quickly change as seen here. When I was at a startup we made sure to get the sysadmin to do some tests to verify the process, and the first round failed. And I think that what we were doing was simple compared to what GitLab is dealing with.
