PropellerIde and Raspberry Pi
Installed PropellerIde 0.38.5 onto my Raspberry Pi (noobs 2.1.0). It will not write/program my Propeller quickstart board
With Openspin- it kind of acts like it blinks the quickstart board and stops
with bstc see picture
appreciate any help, thanks
http://forums.parallax.com/utility/thumbnail/119511/FileUpload/c3/520b83726de4df4a2bf7234e1b3db0.jpg
My mistake I mean PropellerIDE
sorry
There's an open issue for this on github: issue #43, https://github.com/parallaxinc/PropellerIDE/issues/43 (note despite the title, it affects all platforms, not just MacOS)
Regarding bstc, IIRC, BradC, the original author, only ever built an x86/Intel target, and it's closed-source "abandonware", so this unfortunately isn't an option on ARM boards like the Pi (I think someone else in that issue tried the very same thing with the same results).
I was only able to work around it by programming the Propeller manually on the command line after it'd been built using the IDE, or by modifying the PropellerIDE source and building it manually (though I don't know C++ or QT5 well enough to know if it's the right way to fix it).
Cheers,
Jesse
The Pi uses BCM17 as the reset line - this sits high and pulls low for a reset. On the Propeller hat this is directly connected to the propeller chip's RES/ pin without the usual transistor and capacitor arrangement used on the demo boards or Propeller Clip/Plug that detects edges on the DTR or RTS pin and uses those to drive RES/
The Pi GPIO pins to use are 6 or 14 for GND, 8 for TXD (data out of Pi), 10 for RXD, and 11 for the reset.
I'm using the (Pi version) PropellerIDE Version 0.36.7
In Preferences, I have the Compiler set to /usr/bin/openspin and incudes set to /home/pi/propeller - which is the folder where I keep my Spin source code files.
Just make sure you pull gpio 17 low long enough.
Manually this works:
gpio -g mode 17 output
gpio -g write 17 0
gpio -g write 17 1
If you want to fit a 'normal' propeller EEPROM you can purchase a DIP EEPROM 24LC256 or 24LC512 chip and wire it up in the breadboard area - you only need the chip plus one 10K resistor.
I ended up wiring my Pi Propeller hat to a cheap Chinese 3.3V FTDI so I could use it with a regular PC rather than the Raspberry Pi. This was mainly because my Pi only has a small screen and keyboard which were awkward to use for programming.
