Batteryless, wireless transmitter (energy harvesting)
A friend told me about this " Self-Powered Battery Free Transmitter with Receiver Remote Control"
Acegoo Wireless Lights Switch
A product reviewer said a company named EnOcean developed the technology behind this product (and many similar products):
https://enocean.com/en/technology/energy-harvesting/
https://enocean-alliance.org/en/products/?tx_f03enocean_pi1%5bprodukthauptkategorien%5d=5
Has anyone come across a hobbyist version of this technology? Pretty sure it uses piezoelectricity to supply power...
Energy Harvesting - EnOcean Alliance solutions make use of energy created from slight changes in motion, pressure, light, temperature or vibration. The self-powered wireless sensors help make buildings smarter, safer, more comfortable and more energy-efficient. No batteries - product manufacturers, building professionals and end-users can now realize the promise of battery-less and wire-free control systems. Because they are anchored by self-powered sensors and switches, EnOcean-enabled buildings are more flexible and cost-efficient to design, build and operate.
They are using temperature differences - Peltier effect devices
And whatever else.
The trick then is to have a super efficient power supply to convert whatever you get from the power source to something that can be used to charge a battery/capacitor and power your gadget. Even if only for a short time every day or whatever.
LoRa Wireless technology or even ZigBee will perhaps get you the low power wireless connection.
For sure I have stumbled across hobbyists experimenting with these things. For example:
https://sparkfun.com/products/9946
linear.com/product/LTC3588-1
It occurred to me back then to use this technology to make a wireless light switch for a lamp. Put a standard-looking switch in the remote clicker and stick on a wall. I tested it and it worked OK. I looked briefly at making it into a commercial product, but the lawyers I showed it to warned that the transmitter generates broad-band interference and was actually illegal in the US. This was originallly a Japanese toy, imported here in small volumes.
They are pretty pricey too!
I am kind of confused.
A wireless switch without transmitter or receiver is just a switch. Like any other switch you can buy without any wires on it.
What am I missing?
Don't even ask about my cordless screwdriver.
... it's rather amazing how much voltage you can generate across a piece of wire if it is resonating at the right frequency. That is the trick though.
Power transfer test video:
Sorry Mike! I meant to say Digikey has lots of piezo switches... DUH!
