Looking for good reflow oven in the $500 range
JohnR2010
All, I'm in the market for a reflow oven and just came across this oven on Amazon ChefStore Reflow Oven $517. Does anyone have any experience with it or a recommendation on another oven?
http://www.ebay.com/itm/T962A-Infrared-SMD-BGA-IC-Heater-Automatic-Reflow-Oven-Soldering-Area-300-320mm-/140609016665?hash=item20bcf35359:g:OAcAAOSwiONYLmpx
Did you have to do any of that stuff??
That smell won't go away for days.
What brand and model? Stock or modified? Details, details...
Rick
I was lucky enough to have one of my assembled boards put on an X-ray machine. There's a QFN Propeller in the bottom middle of solder_a.jpg. The blobs that look like solder bridges are SMD capacitors on the other side of the board.
That is one expensive toaster oven.
Rick
I ordered the oven that Dave Jenson and Tony P. have above and if it doesn't work I will send it back. Seems like the newer ovens work better so i have my fingers crossed. I'm not going the toaster route i have enough stuff I have to "make work". Thanks everyone for the input!!
Thanks, I plan on doing several test / calibration runs to get a feel for it.
T962A from Amazon I know I paid more than I needed to since I bought it from Amazon but I wanted to have no issues if I needed to return it. The date code on the unit was 16/7 so I'm guessing that was July of last year (2016).
