Blocklyprop loop stops
Carol Hazlett
Running this loop my microcontroller, a Propellor Activity Board, fairly new but not a WX hangs up and quits on 7th iteration of steps in loop. If I use RAM it quits altogether and when I use eeprom it quits for a short pause then starts up again. It isn't hanging on the end of the loop but goes back to the first step executes it then quits. I attached the code for anybody to look at. This is the untuned beginning of a walking gait for a three servo walker. Any ideas would be appreciated.https://forums.parallax.com/utility/thumbnail/119421/FileUpload/1b/b570a56cbfcfa03ad08e64cac79d6d.png
Does your Blockly generate C or Spin? If the latter, can you post the code it generates? I'm still thinking reset, but since it's so predictable, maybe it's the software that's triggering it.
Unfortunately, SPIN support is not up and running, just C.
