embeded "case" question and Variable check
Ltech
What is the best way to control the integrity of some manual imputed variables ?
Try to get ValidHex 1 for pased check, and $F if not
need to check the "ID, Tslot , STx, TxPos" variables
This one do not work
Thank-you
PUB ControlVars
ValidHex := $F
case ID
0..200 : case Tslot
0..2 : case Stx
1..10 : case TxPos
0..9 : ValidHex := 1
other: ValidHex := $F
PUB ControlVars
case ID
0..200 : case Tslot
0..2 : case Stx
1..10 : case TxPos
Thank-you
Only I'm sure nesting a case within a case within a case is the road to confusion and madness.
I need to control the manual input of variables.
Each of them have to be inside strict limits.
We use them for time multiplexing so no fault are tolerable
We store the variables in the eprom, and notice we can have bad recall when program to ram while testing. (I know why)
We want to make inputs the most fool prove we can ...
In stead of doing "if " I find the "case" a compact way of quick check limits
If al "case" are passed, we know all variables are in the range
So is this a correct way do do this ?
Somebody a other system to do this trick ?
For example, if you were checking to see if a character is a vowel or a consonant, a case statement would be ideal, because the set of inputs is not continuous. On the other hand, checking to see if a character is a number is simpler with an IF statement because the range of things being checked is a continuous, single range.
In your example, I'd suggest using this instead:
if (ID => 0 AND ID =< 200) AND (TSlot => 0 AND TSlot =< 2) AND (Stx => 1 AND Stx =< 10) AND (TxPos => 0 AND TxPos =< 9) ValidHex := 1 else ValidHex := $FIn an optimizing compiler this will short-circuit at the first failed test, though I think Spin evaluates everything in an expression, so it might be more efficient to use nested IF statements, like this:
ValidHex := $F if ID => 0 AND ID =< 200 if TSlot => 0 AND TSlot =< 2 if Stx => 1 AND Stx =< 10 if TxPos => 0 AND TxPos =< 9 ValidHex := 1Given a program with inputs A, B, C I might start with something like:
IF A is not valid EXIT ELSE IF B is not valid EXIT ELSE IF C is not valid EXIT ELSE do stuff with A, B, CIn a sloppy pseudo code.Of course things get more complex if the validity of A or B or C is not independent of each other. Perhaps certain combinations of them all are valid but other combinations are not.
Either way, when I find myself nesting "case" or "if" or whatever too much I start to think there must be a better way to express what it is I actually want to do.
PUB Inputs 'adc.average(channel, n) repeat temp1 := adc.in(0) >> 3 Case temp1 0..30 : F_B := 10 'back 31..91 : F_B := 9 92..154 : F_B := 8 155..216 : F_B := 7 217..230 : F_B := 6 231..310 : F_B := 0 'midpoint 311..350 : F_B := 1 351..400 : F_B := 2 401..460 : F_B := 3 461..510 : F_B := 4 511 : F_B := 5 'forwardA range of values for a joystickPRI NewStepLS(n) | coil coil:= n // 4 case coil 0: outa[11..8]:=%1000 1: outa[11..8]:=%0100 2: outa[11..8]:=%0010 3: outa[11..8]:=%0001Output for a stepper motor.
Only that when you find yourself nesting case within case within case, that might be a clue that ones program needs a bit of thinking about before it becomes an unreadable mess.
I like a "case " to check for particular cases. Like 1, 2, 3.
What we have here is a check over ranges of values. And then nested....
It does not express what the intention is.
Actually, thinking about it, I don't like "case" at all. It's as if the "structured programming" gurus wanted to ban GOTO because it makes a spaghetti mess out of your code. But then they had to put in "case" to do what you needed GOTO for in the first place!
If your cases are 0 based and sequential, the code becomes a jump table. Some compilers even allow a non-zero base, and subtract the offset at runtime. If your cases are discrete and non-contiguous, they can be sorted, and the compiler can generate a binary search / decision tree to efficiently decide on the target code.
If the user creates a sequence of if/else statements, the generated code is entirely dependent on the order of those statements, so it's up to the creator to make it efficient.
In the case of Spin, with ranged case statements, I'm pretty sure the under-the-hood implementation is equivalent to a sequence of if/else statements, which makes me die a little inside.
So, in a high level language, should one design the the thing to micro-optimize low level machine features. Or design the the thing to make it easier for humans to express what they mean and share that with other humans?
For example, the C language seems to have a ton of things that make it easier for compilers. In favor of encouraging the writing of clear code for humans to read.
The "case" is one such example.
switch( userChar ) { case 'L': case 'l': turnLeft(); break; case 'R': case 'r': turnRight(); break; default: Message( "Invalid command" ); }To me that's more readable than:
It also lends itself well to doing things like this:
switch( LowerCase(userChar) ) { . . . }...whereas the if-based version would need to re-do the LowerCase() call for each if/else, or use a temporary variable.
Ultimately it's just another tool in the toolbox. Part of what makes an good programmer is knowing what the various tools are good for and using them effectively.
I am with Phil, "case" is more readable for me regard complex "if then".
But Jason way is nice too.
In my part of the program case will do it, but for more complex nested brunch I use "if then"
The layout here make it not nice tabulating, so I make it viewing nicer...
PUB ControlVars ValidHex := $F case ID 0..200 : case Tslot '# ID 0 to 200 check 0..2 : case Stx '# Tslot 0 to 2 check 1..10 : case TxPos '# Stx 1 to 10 check 0..9 : ValidHex := 1 '# TxPos 0 to 9 checkPUB ControlVars If (ID => 0 AND ID =< 200) AND (TSlot => 0 AND TSlot =< 2) AND (Stx => 1 AND Stx =< 10) AND (TxPos => 0 AND TxPos =< 9) ValidHex := 1 else ValidHex := $FThank-you
Instead of checking for everything at once it would make more sense to check each item at a time so it can be flagged as bad.
One of the most frustrating things that a program can do is just tell the user there was an error and not what the error was.
If something is bad then you can tell the user that is was bad and to enter it again.
Also, remember that Spin has TRUE and FALSE which are a lot more meaningful in this situation.
If the program is getting Hex values then why not check them in Hex.
In fact they are dec values.
@Genetics
Of course we check on every entry, but we notice (ex on new ram program loads) some time the variables, taken from eprom on startup, are wrong.
We know why, we do not expect it on field use, but it can happens.
My vision to handle this is checking if the values are in specs when read the eprom variables.
If we have a buffer overrun, at least we do not eventually lose al the modules in the time multiplex, by random jamming of that module.
The module go to standby, give a alarm, and we can make a manual connection
Project description:
This is used on complex antennas tracking, with a lot of realtime moving vehicles. (motorbikes, helicopters, plane, ground station)
The time multiplex is locked on 1pps gps, sending all dada on one 15khz uhf frequency.
We need it to build the first tracking of the antennas.
Once we have a basic track, we use the up and down freq to embed the tracking data.
On lose of those freq, we go back on the uhf tracking.
PS the "case" option only compile on BTS
pub process_shot | x if (HitDelay) ' hit delay enabled? if (htimer.millis < 0) ' if timer running return ' abort else htimer.set(-hitdelayms) ' restart hit delay timer if (buffer[0] & $80) ' validate shooter return x := buffer[1] & 1 ' validate field if (x <> FieldID) return if (FFire == NO) ' ff disabled? x := buffer[1] >> 5 ' extract team if (x == TeamID) ' abort if match return x := (buffer[1] >> 1) & %1111 ' extract damage x := damage_points(x) ' convert to points take_damage(x, buffer[0]) ' deal with damageInstead of deep nesting, I use return to abort the process. This doesn't work for all cases, of course, but I find it helpful from time-to-time.
