Need some code help for PST - Lost little lamb...
in Propeller 1
Hello,
I'm working on a personal Propeller project that uses two sensors to measure a fan blade track path, (right now ceiling fan). Plan to measure via triangulation by knowing the times the blades are between beams. I'm currently stuck in that I can seem to properly grasp how to make a line cascade downward in PST. I want to take a reading "BeamTime(nS)" and make 5 columns of data and have it append once for each full revolution of the fan. (Five blades = 5 timing events per revolution). I've been able to modify xTach by Mark Owen to get to a really good starting point but stuck with displaying the times. I could use a little code help in getting over the hump, any help is much appreciated. I've attached the spin files and a screen shot of what I currently want to display on PST.
Couple of questions:
1. How can I make data row one in the screen cascaded down with each value update? I know its simple but I've not been able to figure that out.
2. As stated above I'd also like to just have the second data row (Blade#1-n) cascade down with each update. I"ve tried #NL commands and other options, I know it must be simple...
Thanks in advance,
Chuck
{{ Developed from: ┌───────────────────────────────────────────────────┐ │ xTachTest.spin version 1.0.0 │ ├───────────────────────────────────────────────────┤ │ │ │ Author: Mark M. Owen │ │ │ │ Copyright (C)2014 Mark M. Owen │ │ MIT License - see end of file for terms of use. │ └───────────────────────────────────────────────────┘ Description: Demonstrates usage of the xTach methods for determining the activity on an input pin: Pulse width in system clock ticks Pulse frequency in Hz (cycles per second) Pulses per minute Revolutions per minute Uses the Parallax Serial Terminal for output at 115,200 baud for output. Written as a means of circumventing jitter found to be present when using assembly language frequency counters for low frequency signals (in my case a belt driven aircraft prpeller with 39 teeth per revolution on the main drive pully which runs at a maximum of 3600 revolutions per minute). Has been tested using a signal generator from 1Hz to 50kHz and found to be accurate to better than 98% over the range tested with the largest errors at frequencies less than 30Hz (2%). Revision History: Initial version 2014-10-16 MMOwen Added Decay function 2014-10-18 MMOwen }} CON _clkmode = xtal1 + pll16x ' System clock → 80 MHz _xinfreq = 5_000_000 ' external crystal 5MHz TACH_PULSES_PER_REVOLUTION = 5 ColPos = 8 OBJ TACH : "xTrack" pst : "Parallax Serial Terminal" VAR long Blade[6] long Buff[6] PUB Main EnablePST TACH.Start(8) pst.Position(0,0) pst.Str(string("PkPkTicks")) pst.Position(15,0) pst.Str(string("Hz")) pst.Position(30,0) pst.Str(string("Pulses/Min")) pst.Position(45,0) pst.Str(string("RPM")) pst.Position(60,0) pst.Str(string("BeamTime(nS)")) pst.Position(30,5) pst.Str(string("Blade Timeing")) pst.Position(0,6) pst.Str(string("Blade#1")) pst.Position(15,6) pst.Str(string("Blade#2")) pst.Position(30,6) pst.Str(string("Blade#3")) pst.Position(45,6) pst.Str(string("Blade#4")) pst.Position(60,6) pst.Str(string("Blade#5")) repeat pst.Position(0,1) pst.ClearEnd pst.Dec(TACH.PulsePktoPkTicks) pst.Position(15,1) pst.Dec(TACH.Hz) pst.Position(30,1) pst.Dec(TACH.PulsesPerMinute) pst.Position(45,1) pst.Dec(TACH.RevolutionsPerMinute(TACH_PULSES_PER_REVOLUTION)) pst.Position(60,1) pst.Dec(TACH.BeamTime) pst.Position(0,7) pst.dec(Blade[1]) pst.str(string(" ",8)) pst.Position(15,7) pst.dec(Blade[2]) pst.str(string(" ",8)) pst.Position(30,7) pst.dec(Blade[3]) pst.str(string(" ",8)) pst.Position(45,7) pst.dec(Blade[4]) pst.str(string(" ",8)) pst.Position(60,7) pst.dec(Blade[5]) pst.str(string(" ",8)) TACH.Decay waitcnt(clkfreq/5+cnt) PRI EnablePST pst.start(115200) repeat pst.Home pst.Clear pst.str(string("Start tests: press .")) pst.newline repeat while not pst.RxCount pst.Char("~") waitcnt(clkfreq+cnt) if pst.CharIn == "." quit pst.Home pst.Clear
Thanks in advance,
Chuck
I'm not sure exactly what you're trying to do, but you can position the cursor at X/Y coordinates, so that would allow some flexibility over #NL.
Using your suggestion I was able to answer my question #1, though when I used the "%5" I get an "Invalid Binary #" error for that part of the code. I am able to cascade the values down the screen as they update, just in infinity...
Jason/Chris,
However for my question#2, I need help in getting the "BeamTime" object to fill in for each blade. I guess I'll need to make an array to fill those items in? What I'm trying to do is to fill in horizontally the beam time value for each blade and then start over again on a new line. So first value would start under "Blade#1" and the second on "Blade#2 and so on until it gets to "Blade#5 and then start a new line.
Chuck
What I'm currently trying to do is take the data output as "TACH.BeamTime" and display it in PST relative for each blade of the fan. There are five blades so five timing outputs for each revolution of the fan. I think what I needed to do is output "BeamTime" as a string and distribute that to each "BladeCounts"[0-4]. I just can't seem to understand how to accomplish this... Later on, I plan to add an additional optical sensor to mark each revolution of the fan so I can be assured that blade 1 is blade 1 and, blade 2 etc.
Additionally, what is the "8" designating in "pst.str(string(" ",8))"
Is this the # of bytes or "Y" axis plot?
Thanks in advance,
Chuck
The second would be to convert the time to ascii characters, store them as a dat string, and print the entire line.
Attempted making changes using your version 1. Still no luck. New code is shown below. I also attached a screenshot of PST, showing that I'm getting the text plotted but the values aren't getting updated in the columns.
TIA,
Chuck
