Astronomy Picture of the Day
This had caught my eye as quite an achievement, a mosaic photo of the far side of our moon.
http://antwrp.gsfc.nasa.gov/apod/ap161230.html
Commence discussion.
One thing is for sure, I'm glad our moon is out there fielding for us.
The Moon was much closer to the Earth when it formed; it has been being lifted ever higher by tidal forces (and the Earth's day getting longer, which is where the energy for the lifting comes from). When the surface of the Moon was cooling it was still close enough that the Earth's sucked up or deflected a significant amount of stuff that would have gone on to hit Nearside if the Earth hadn't been there. But Farside wasn't shielded and soaked up everything coming at it. The bombardment consisted of stuff that got smaller over time, as the big stuff was more likely to be drawn in, so the shielding had the effect of protecting the Nearside maria, which were themselves the results of very heavy early impacts, from being obscured and covered up.
If nothing interfered the tidal thing would eventually end up with the moon about 1.5x as far from us as it is, and the Earth's rotation tidally locked. However, long before that happens the Sun will become a red giant and most likely swallow both the Earth and the Moon.
Love it anyway.
As far as cratering on the near side versus the far side, it looks very similar to me in areas where the maria don't exist.
Another thing that is interesting about our moon is, the lack of any rotation. It would be hard to keep any small mass at one point in space, an object the size of the moon must have specific forces keeping it facing in one direction to us.
That is one thing I could never understand.
The tidal force from earth's gravity has locked the moon's rotation to it's orbital rotation. Same is true of Mercury with respect to it's orbit around the sun. Both still rotate relative to the rest of the universe. The rotation is just locked in step with their orbital rotation period.
-Mike R...
1) The strength of gravity decreases with the square of distance.
2) Therefore a sizable object, planet, moon, etc orbiting something else, experiences a higher gravitational force on the side nearest its partner than the far side.
3) This force difference results in a stretching of the object. What was a sphere is not exactly a sphere anymore.
4) But as our object is rotating it is being stretched out of spherical in different directions all the time. As we see with the way the actual ocean tides rise and fall, thus making the Earth not exactly spherical in different ways everyday.
5) The resulting friction as things stretch and squeeze around sucks energy out of the rotation. Thus slowing it down.
6) Until, the object no longer rotates with respect its partner.
In the scale the size of planets, it is a delicate balancing act.
Exactly. Wish I could express my thoughts/knowledge as well as your explanations.
The closer the small sphere is to the big sphere the worse it gets, so all planets very close to their sun are quickly tidally locked, with the same side facing the sun all the time.
We live on a well designed spaceship, with all the billions upon billions of possible places for life out there, the probability of something like we have may not exist elsewhere.
Sometimes I speculate that with a couple of billion stars per galaxy and a couple of billion galaxies in the observable universe, then surely there is some complex "life" out there somewhere. That's a lot of stars and a lot of planets. Some of them must work.
Other times I find myself reading about what freak situations had to happen to make it possible that we are here. It's vanishingly probable.
I had tried to get a download of the image that Clock Loop had posted, so far all I can get is a screenshot 1920 x 1080. Did anyone have luck in getting better quality? Makes a nice computer background.
https://astrobites.org/wp-content/uploads/2014/06/NearAndFarMoonWiki.png
EDIT: maybe the best quality images come directly from the source:
https://www.nasa.gov/mission_pages/LRO/
main/index.html
Here is some vids to investigate:
http://lroc.sese.asu.edu/images/videos
This one is downloadable:
http://lroc.sese.asu.edu/videos/wac_moon_643nm.mp4
IMHO, AWESOME
Did you happen to notice this crater, around the 3:30 position on the backside photo. Looks like a very large very fast object caused that. Something hitting the earth on that scale could be very bad for our environment. I think we dodged a game changer.
"Rerun" asteroid buzzes Earth in second close shave of 2017
http://www.cbsnews.com/news/asteroid-seen-buzzing-earth-second-close-shave-of-2017/
http://antwrp.gsfc.nasa.gov/apod/ap170326.html
It's possible that earth is the first instance of life. Someone has to be first.
Sandy
Given the numbers involved the odds of us being first seem pretty slim.
Just what is our place in the universe? Are we on the outer edge somewhere, in one of the farthest galaxies from a perceived center.
If this creature was on this planet since it was formed, it would need some pretty extreme capabilities to have survived. Everything on this rock had to have those capabilities, if you weren't born with them, you evolve into something that can survive or die out like the dinosaurs.
This creature could have led to the idea behind the aerosol straw.
If you listen to cosmologists they will tell you about the "Cosmological Principle". Which basically is the assumption that the universe looks pretty much the same no matter what direction you look in. And that it looks pretty much the same no mater where you are in it.
As opposed to living in some crystal lattice where different directions would look very different.
So, while it looks to us as if the "big bang" started the universe from a point. It is not so.
Why? Because if you were a being living a billion or so times further away than the size of our observable universe you would make the same observation.
And also because, if the thing started from a point somewhere then the universe would look somewhat different when we look back in the direction of that point to looking the other way to the direction we are expanding into.
My take away from all this is that the original "point" of the big bang was not a point at all. It was infinitely dense but also infinitely big. Now it is less dense but even more infinitely big.
As for those tardigrades. I was wondering....
It seems almost impossible to kill them. They can survive almost absolute zero temperature. They can survive boiling. And the huge pressure of the depths of the ocean. Or the vacuum of space. They can do without food and water for ages. They don't care about radiation.
As such, I start to think, they are at an evolutionary dead end. If they can survive anywhere, there is no pressure to evolve differently.
Terence had a pretty good idea...
If you consider that the universe is not only infinitely BIG, but also infinitely small, you are left with only possibilities.
Carl, help a dude out..
Sure do miss Carl. Remember him all the way back to the Tonight Show. An extremely friendly sort of Astro Physicist who could get the point across at a basic level even a kid could understand.(which I was). The way he said "Billions and Billions" of stars, is indelible in my mind. He was a major influence in piquing my interest in space science.
https://en.m.wikipedia.org/wiki/Carl_Sagan
Thanks Heater for the spell check.
https://www.vocabulary.com/articles/chooseyourwords/peak-peek-pique/
