PropellerIDE/PropBASIC
Mickster
"If", "endif", "or", "and", etc., are highlighted keywords but "then" is not. Is there a way to manually add this keyword or is it hard-coded somewhere?
Also, a PropBASIC coding error. such as an if condition without a then, causes PropellerIDE to crash (XP).
LOVING this combo of environment and language for the Prop....why oh why does PropBASIC not have a bigger following?????
There are "Active", "Reset", "Clear" buttons.
"Clear", clears the display, "Reset", resets the Prop but deselecting/re-selecting "Active" also resets the Prop. Is this reset supposed to happen?
