OUTA[26..23] := 0b1011; in Propeller C
in Propeller 1
Hello,
i converted an assembler program into C
I was trying to use OUTA[26..23] := 0b1111; to set some bits, but I get error
to many decimal points in number;
I need to set a specific range of pins to a pattern without affecting pins outside the range above or below
like
OUTA ^= 0b101010101010101 << 26;
any help would be helpful
thank you
regards
Jeff
like
thank you
regards
Jeff
That will do the same thing in C/C++ as
in Spin.
Where "mask" is the bit mask of pins you want to write, and value is the value you want written to the port.
Example:
Source
Beat me to it
Ex:
This will set bit 23:
var |= (0x01 << 23); // set
This will clear bit 23
var &= ~(0x01 << 23); // clear
This will toggle a bit each time it is called:
var ^= 0x01 << 23; // toggle
These could be placed in a function where you have a start and stop value for a range.
The Macro way would be to do something like:
#define BIT_MASK(bit) (1 << (bit))
#define SET_BIT(value,bit) ((value) |= BIT_MASK(bit))
#define CLEAR_BIT(value,bit) ((value) &= ~BIT_MASK(bit))
#define TEST_BIT(value,bit) (((value) & BIT_MASK(bit)) ? 1 : 0)
However, for a range, you would look at some sort of loop or a function that accepts a range to set or clear or even toggle a bit, or use the other great examples the David's have posted.
// This will produce:
This is a test
Original value of OUTA = 0x00020304
Set bit value 25 = 0x02020304
Clear a bit 25 = 0x00020304
After set bit 23 = 0x00820304
After set bit 24 = 0x01820304
After set bit 25 = 0x03820304
After set bit 26 = 0x07820304
http://learn.parallax.com/tutorials/language/propeller-c/propeller-c-simple-circuits/seven-segment-display
I'm putting together a Noise Level Indicator project and this might come in handy with outputting the sound levels to a Bar Graph display.
There's a great example of using PropWare and an MCP3000 (an ADC) to turn the 8 LEDs on a Quickstart board into a bar graph, just as you're looking to do. Long version here, and short version following:
And here's a simpler snippet explaining the PropWare::SimplePort object's use:
This code will set the direction and write alternating 0s and 1s. Just like Simple's set_outputs() function, the shifting is done automagically for you. SimplePort is designed for ports with all pins in consecutive order. Ports with pins in non consecutive order can make use of PropWare::Port.
Interestingly, my PropWare example is actually 100 bytes smaller than Andy's Simple example (2,364 vs 2,468 when compiled in LMM). Sometimes, C++ does indeed win
Nice!
Not to hijack this discussion but I have a example working with an Arduino board where I have the sound input through an OpAMP which is then sent to the Arduino where the LED range on the Bar Graph is determined by a mapping between the input value and the appropriate LED or LEDs on the Display. This is done without an I/O expander however I do like the idea of using something like a MCP3000 series device to reduce the number of connections.
I'll have to give this whirl.
Thanks!
I wish it were true. Unfortunately, it isn't, and you can't use the "using" keyword with enums either (no "using PropWare::Port::Mask") - not even class enums. In fact, I won't swear to it, but I don't think you can even use it with inner classes. Here's the error message that GCC 4.6 throws with "using PropWare::Port::Mask":
