Programming And Customizing theMulticore Propellor Microcontroller Lesson 1 WIP
microcontrolleruser
in Propeller 1
Spinners
I've got the PPDB out.
First lesson is wiring up 8 leds.
Any tips?
Happy Holidays!
Any tips?
Happy Holidays!
etc the P7 connected to LED8.
Then download https://parallax.com/sites/default/files/downloads/122-32305-PE-Kit-Labs-Fundamentals-Text-v1.2.pdf this text book.
Begin on page 33, except the resistors are built in and the switches are active low.
Thank you.
You read the part where we have that circuit built on PEKit in the other post?
I sort of thought it sounded familiar and I've noticed how Parallax recycles
some of their info.
Happy Holidays!
Well no bank of LED's on PPDB. I guess that would be a little too simple minded.
Why couldn't they start with 7 Segment LED experiment?:)
Okay this is going to take some time.
Happy Holidays!
There is a bank of 16 LED's on the right side of the board ready to get lighted up.
This is a Rev A grey board.
With Spinner hat emblem in upper right corner and external connectors along left edge of board.
Upper right bank is 7 Segment led's, Three pairs of two. Six total.
You say use those in place of single parts component led's?
Happy Holidays!
Below the Propeller hat logo, there is a bank of 16 individual LEDs.
Thank you for your time and effort!
I thought that was a blank spot on board.
My board is a little filmy like someone smoked around it.
Then it's gray and lights don't stand out and they're awfully small.
Merry Christmas!
You could always wire up a 7 segment display with a decimal point and treat it as 8 individual leds. That is what it is. Do your led experiment and leave it wired for the 7 segment experiment.
It's under control now.
Keeping 8 page PPDB user guide and scematic handy.
Going to test LED's next before running experiment.
Merry Christmas!
I want to test led's first.
Any tips on jumpering from 3.3 and 5 volt blocks to
push button and then an led?
Then there ought to be led ground to ground block but will check schematic.
See if leds are just grounded. Think they are.
Merry Christmas!
You can test an LED without the Propeller by running a wire from +3.3V to the LED, which should turn it on.
EDIT: Cathodes, not anodes.
Thanks!
Sort of came around to that. Tested push buttons and dip switches while I was at it.
Where is this source code for book?
Here's an old post.
http://forums.parallax.com/discussion/142893/pcmprop-question
Tried that link and got 550 error.
Happy Holidays!
ftp://ftp.propeller-chip.com/PCMProp/
https://www.dropbox.com/s/qo8swwt9fanj0sf/Propeller Book.zip?dl=0
Cathodes (K) are grounded.
Thank you for the effort!
Unfortunately when you click on source code in Chap 1
text readme says there isn't any.
Happy Holidays!
I jumpered over from 3.3v to first pin on led bank.
When nothing happened I stopped.
Looked at 7 segment led datasheet but these seem different.
Looked at PPDB schematic also.
Seems like something I need to go through lesson with to get it.
Happy Holidays!
That is because chap 1 doesn't have any source code. It is the prop manual. Read the readme at the top level.
How about posting a photo clearly depicting how you jumpered.
Can you measure 3.3v? With respect to the ground post at the top left corner.
You'll probably want to jumper the power rails on the breadboard. Each power rail is split in two. I use four small jumper wires between the four pairs of center power rail holes.
1 This board is connected to Parallax 7.5v power supply. USB is for sending program to RAM on the board.
Maybe the Propellor Proto board is USB powered if any on them. Would have to look.
2 Ooops! In Chapter 2.
I ran led program from Spin tutorial that came with Propellor Tool.
Guess now that we found source code we'll start over and
do it according to book.
Happy Holidays!
The early Propeller boards required external power but there have been a bunch of Propeller boards which can be powered from the USB connection.
Here's few off the top of my head.
Propeller Activity Board
QuickStart Board
Propeller Board of Education
C3
Propeller Project Board
Some of the ones requiring external power include:
Propeller Proto Board (USB and Prop Plug versions)
Propeller Demo Board
And as you're aware the PPDB
Thanks. I updated my post. I thought I had finally gotten them straight, but I guess I was wrong...
Not unlike the symbol for an NPN (bipolar) transistor. "Not Pointing iN"
Propellor Developers
Finished running code on board. It worked.
Did a little testing on the board it works fine.
Giving it a break today.
Thank you Tom. Thank you Duane.
Merry Christmas!
