code for color sensor #28302
in BASIC Stamp
In 2003 Jon Williams wrote a program called "color me Tickled" does any one have a working copy of the code? I have worked on this program for a week I need help. It up loads the color sample information but will not sample the colors. I teach Stem and I want to use it in a color scanner. Or do you have a better program?
https://www.parallax.com/downloads/nuts-and-volts-basic-stamps-volume-4
Chris Savage | Engineering Tech | Main Office: (916) 624-8333 | Direct to Tech Support: (888) 997-8267 | www.parallax.com
Visit our forums at http://forums.parallax.com
Welcome to the forum!
2. Which BASIC Stamp and board are you using this with?
3. Which sensor pins are connected to which Stamp ports?
4. Can you post the program that you're trying to get working?
#2 I am using the usb version of the stamp board.
#3 p-1 to output P-2 to S2 , p-3 to s3, p-0 to LED, Vcc to +5 volts, Vss to gnd, Vdd to + 5volts .
#4 I am using the program Jon Williams wrote. Its on Parallax nuts and volts. document web sight.
I am new to this procedure. It is a long program but I will try if you Dem it necessary.
Thank you very much for your consern.
There was never any glue involved in the manufacture of the TCS230-DB, and all devices were functionally tested 100% before shipping. Might the glue have been added later?
The entire program is #98 on the web sight. Thank you
The program in Jon's article should work fine. I'm operating under the assumption that your TCS230 has a hardware issue, given your description of the sensor chip's condition.
When you receive the new module, could you send me the old one to my return address, please, so I can have a look at it? I'm curious about what happened to it.
