(NEED HELP) I need the code for a digital clock using just the DEBUG TERMINAL SCREEN
in BASIC Stamp
Using no components just the basic stamp and computer.
Design code to display time onto the terminal screen.
Need to be able to set anytime and have it go through the cycle.
@xanadu
@xanadu
Can you post the code you have so far?
So i have pretty much not really gotten far at all i just dont know what i am supposed to use.
I have this right now but this is like the 5th thing i have started lol i just really need help in general
' {$STAMP BS2}
' {$PBASIC 2.5}
secs VAR Byte '
mins VAR Byte '
hrs VAR Byte '
startVal VAR Byte
endVal VAR Byte
Setup:
startVal = 1
endVal = 60
mins =1
Main:
FOR secs = startVal TO endVal
PAUSE 1000
DEBUG CRSRXY, 100, 12, DEC secs, CR
DEBUG CRSRXY, 98, 12, DEC mins, CR
IF (secs = 60) THEN
startVal = 1
endVal = 60
DEBUG CRSRXY, 98, 12, DEC mins +1, CR
ENDIF
NEXT
DEBUG CRSRXY, 98, 12, DEC mins = DEC mins + 1
End this line of code like the lines above it, increment your mins var on the next line. Then you can add hours after it.
Here is a simple example using IF/THEN. There are cleaner ways to do this, but this is the easiest to
understand IMO. Now you can apply the same thing to what you have. -
DO secs = secs + 1 'clock interval, normally 1 (changing will break am/pm) PAUSE 970 'loop execution offset ~970 for updating terminal IF secs = 60 THEN mins = mins + 1 '60 seconds passed IF secs = 60 THEN secs = 0 'reset seconds IF mins = 60 THEN hours = hours + 1 '60 minutes passed IF mins = 60 THEN mins = 0 'reset minutes IF hours = 13 THEN hours = 1 '12h time format IF hours = 11 AND mins = 59 AND secs = 59 THEN GOSUB tampm 'toggle AM PM GOSUB update 'update display LOOP
I start a loop for seconds, and then pause for just under a second to compensate for the rest my code. When the seconds equal 60, minutes go up, and then seconds are reset. When minutes are 60 hours go up and minutes are reset. When hours hit 13 we reset them to 1. When it's 11 hours and 59 minutes and 59 seconds we can toggle AM/PM status.
When you output to the terminal you don't need the ",CR" (carriage return) at the end when using CRSRXY. I would setup the display first, this would only run once:
reset: DEBUG CRSRXY, 1, 0, "Basic Stamp II Clock" 'setup terminal DEBUG CRSRXY, 1, 2, DEC2 hours DEBUG CRSRXY, 3, 2, ":" DEBUG CRSRXY, 4, 2, DEC2 mins DEBUG CRSRXY, 6, 2, ":" DEBUG CRSRXY, 7, 2, DEC2 secs IF ampm = 1 THEN DEBUG CRSRXY, 10, 2, "PM" IF ampm = 0 THEN DEBUG CRSRXY, 10, 2, "AM" return
Then I would run the timing loop and update the display like this. You will notice DEC2 that will format the number as two digits, 2 = 02, which makes it feel more like a clock to me.
update: DEBUG CRSRXY, 1, 2, DEC2 hours 'print hours in 2 digit format DEBUG CRSRXY, 4, 2, DEC2 mins 'print mins in 2 digit format DEBUG CRSRXY, 7, 2, DEC2 secs 'print secs in 2 digit format return
DO PAUSE "somewhat less than 1000" Secs = Secs + 1 IF Secs = 60 THEN Secs = 0 Mins = Mins + 1 If Mins = 60 Mins = 0 Hrs = Hrs + 1 ENDIF ENDIF DEBUG DEC Hrs, ":", DEC Mins, ":", DEC Secs, CR LOOP
http://www.parallax.com/go/PBASICHelp/Content/LanguageTopics/Commands/SERIN.htm
Toward the bottom you will see usage examples.
http://forums.parallax.com/discussion/77867/ds1302-demo-code-updated
