Did any one read the article in Nuts and Volts by Chris Savage about Mixing Voltage
Systems - Interfacing 5 volts and 3.3 volts Devices
Very well writen article
Please make a link to this info when you can Thanks
Chris's article is much nicer. It should take the place of the thread used in the sticky.
Duane, I've been using a 1K resistor on a 5V input (from a GPS receiver) for several months... no problems.
I believe that somewhere in the previous discussions the issue is not voltage but current... and a 1K resistor is sufficient for keeping the input current at "safe" levels.
In any case, a clear and consise guide on this subject would be welcome!
Walter
http://www.mouser.com/ProductDetail/NXP-Semiconductors/74AHCT245D118/?qs=sGAEpiMZZMs9F6aVvY09bk%2ffb8R74De%2fPssnRSrNzv4%3d
smaller 2bit
http://www.mouser.com/ProductDetail/NXP-Semiconductors/GTL2002DP118/?qs=sGAEpiMZZMsty6Jaj0%252bBBr%252ba7pY41EA16CnqyfpH0m4%3d
I printed this down and added it to my Engineering/hobby note book.
Great info Mr.Savage, Well done.
I came across another IC that can be used 74HC4050 (or CD4050)
OBC
I doubt that it is available online since it is in the April issue but I too would like a digital copy for posterity...
$WMc% said he printed it - maybe he found it or scanned it.
<edit>
Even thought I don't subscribe, I managed to view it on line http://nutsvolts.texterity.com/nutsvolts/201104/?folio=46#pg46
Try this:
http://www.nutsvolts.com/index.php?/magazine/article/april2011_Savage
I don't know if it just works on my machine, because of the memorized Digital Issue login.
OBC
Does a voltage divider circuit provide more protection than just a simple series resistor?
This message is old, but I just ran into it looking for something and thought I would go ahead and answer that for anyone else who may stumble across this and wonder the same thing.
The single series resistor is designed to limit the current, not the voltage of the signal. The voltage divider is dividing and therefore limiting the voltage of the signal.
Jim
Jim
I have been slowly putting stuff back up using Joomla, but ran into a snag when some hacker found a way to shut down my website. Now I'm moving, but should be able to get back to it slowly over the next couple of months in between repacking things.
http://www.savagecircuits.com
