PLX-DAQ error: "Could not load an object"
Hi, I've been searching for solutions on forums but haven't really found a conclusive one for this yet. I downloaded PLX-DAQ to use with Microsoft Excel 2013 on Windows 8, but when I load the PLX-DAQ Spreadsheet, I first get the error: "Could not load an object because it is not available on this machine," then another: "Could not load some objects because they are not available on this machine." Pressing "OK" on both opens a Microsoft Visual Basic Run-time error '424': "Object required," with an option to Debug, which opens the code with "Stamp.Disconnect" under "Private Sub cboPort_Click()" highlighted.
block of code with the error:
Any suggestions?
Private Sub cboPort_Click() Stamp.Disconnect cmdConnect.Caption = "Connect" FlagConnect = False Stamp.Port = cboPort End SubI'm working under admin, and so far I've set Excel to allow macros, downloaded BASIC Stamp Editor, and manually registered selmadaq_ver2.ocx in the Command Prompt.
Any suggestions?
I found out that the original PLX DAQ can only be used with Excel 32 bit versions. Error message is "object not available on this machine" due to selmaDAQ_Ver2.ocx that is not 64 bit compatible)
You can check out the new version I developed with full Office support (32 bit and 64 bit and versions up to Office 2016) on the official Arduino board here: https://forum.arduino.cc/index.php?topic=437398.0
If you have any questions I will try to answer them on the board of course :-)
The new module is now open code and can be enhanced if needed.
Greetings and don't be frustrated anymore! PLX DAQ is very cool and now works with all Office / Excel versions.
NetDevil
(I posted this to all "first search site result" websites I found with Google for PLX DAQ issues so the next users of PLX DAQ can find the new version as fast as possible :-) sorry for grave digging this thread)
