Parral dev board, based on parallax propeller
Hi everybody.
I want to introduce you to my new project, it is a dev board based on the parallax propeller microcontroller. It is a wonderfull dev board for beginners.
I hope you could help me with a like on hackaday.io where you will find more information about the project and soon it wil be on Kickstarter for all you.
https://hackaday.io/project/18178-parral-dev-board#j-discussions-title
Thank so much.
Daniel Garcia
Thank so much.
Daniel Garcia
There have been perhaps a dozen or so designs shared on this forum, such as:
http://forums.parallax.com/discussion/156132/propeller-breadboard
and here
http://forums.parallax.com/discussion/163198/breadboard-friendly-propeller-module/p1
Looks like, (from the Diptrace? screenshot), there is not a whole lot of space to condense. But I would leave out XO, XI and RST. You would not put another XTAL that far away from the chip. The RST is already attached to a pushbutton on the main board?
What do you expect the price to be for the board?
When do you expect the boards to be available?
Cool project. Interested in using it in our school.
1) As mentioned, shrink the width of the tab if possible.
2) Avoid usage of the USB B connector. Use a mini or micro instead.
3) Add access to IO on the main area of the board. Could be simply an extra row of holes on either side of the DIP40.
4) Use a QFP/QFN Propeller to gain real estate. Also gains you the ability to make the board width closer to the width of the breadboard
5) How do you intend to use a DIP40 on the breadboard like mentioned in your project log?
Thank so much for your encouragement David, I will let you know when it be available on Kickstarter
Yes, I Will consider all the tips for this project, now it is in testing phase, and I will consider all your tips for the next review.
the RST pin is attached to a pushbuttom on the main board.
Hi Keith, I buy all the components in stores like Digikey, Mouser, Newark and Parallac inc. so, I trust all the components I am using are originals parts.
Hi friend.
1) the width of the tab can be smaller, but it can be more fragile at the same time.
2) use a micro or mini usb connector is a possibility that I am analyzing.
3) for now, Parral is designed to be used on a breadboard, but I will consider your tip for a future version.
4&5) the porpuse of using that packaging it´s give the opportunity for beginners to learn using the main board and using a more real way to learn electronics, as any engineering student would do it.
Your opinion is very important for me and I am open to new ideas, I will consider all your opinions in a future review, so thank so much for your tips.
Couple of thoughts:
1) Arrange that the board is the same width as a breadboard. Not critical but would make things look very neat and tidy.
2) Use a surface mount Prop. Given that the idea is a DIP connection to a breadboard there seems little point in using a DIP Prop on the board itself. A surface mount Prop would allow the board to be narrower, as in 1). I suspect that smaller boards and fewer holes are cheaper.
3) Be sure to have a power LED on there.
May I suggest consideration that the breadboard rails are changed from VDD-GND __3.3V-GND to VDD-GND__3.3V-5V
5V is often needed on a breadboard!
That is a very nice concise little setup there, going to get more info on it. It looks like a board i'd want to own. Especially when you took care of a lot of the incidentals under the 40 pin DIP. Any power regulation under there? It would be a plug and go, create your own circuit. I'll just follow the link and see what's there, long live the Propeller 40p DIP!
This looks like a nice setup. Please let us know when you have these sets available again.
Thanks for the interest Chris and David, For those interested, here's the M44D40+ module thread.
I really like the design if the M44d40+. It would be helpful to slap a pinout sticker on top of the Prop or on the side of the headers. I'll have to look for the associated thread for this.
Parallax still sells the label:
https://www.parallax.com/product/120-00003
I'm guessing there were too many traces to fit on a 0.3" PCB.
I once considered making a board similar to these and I figured the center arm would need to be four layers if I didn't want to use wires or a wider PCB.
I haven't used my breadboard friendly Propeller boards much since the Quickstart came out.
I invite you to participate and be the first one to get a free Parral dev board
https://www.facebook.com/ParralLabs/photos/a.554267158099885.1073741828.549267565266511/643037069222893/?type=3&theater
Sure. Can we have two please?
One each for my colleague(relative) and I.
Don't like Facebook. Is there another way to do this?
