Question on SCL/SCLU instruction operation — Parallax Forums
Hi All
Can someone confirm the operation of the SCL/SCLU instruction.
It's my understanding the SCLU is basically a MUL instruction followed by a SAR 16 bits.
I assume the same goes for SCL, a MULS followed by a SAR 16 bits.
Is that correct?
If so, here is what I am seeing.
SCL seems to give a result tat is out by 2 bits.
* Test1 SCLU with unsigned values = Ok.
* Test2 SCL with unsigned values = Needs extra SAR 2 to be correct.
* Test3 SCLU with 1 signed value = Fails as expected.
* Test4 SCL with 1 signed value = Needs extra SAR 2 to be correct.
Test #1
  R0           = $000004D2  0000001234
  R1           = $000004D2  0000001234
  MUL R0,R1    = $00173C44  0001522756
  SAR 16       = $00000017  0000000023
  SCLU R0,R1   = $00000017  0000000023
* SAR 2        = $00000005  0000000005
Test #2
  MULS R0,R1   = $00173C44  0001522756
  SCL R0,R1    = $0000005C  0000000092
* SAR 2        = $00000017  0000000023
Test #3
  R0           = $FFFFFB2E -0000001234
  MUL R0,R1    = $04BAC3BC  0079348668
  SAR 16       = $000004BA  0000001210
  SCLU R0,R1   = $000004BA  0000001210
* SAR 2        = $0000012E  0000000302
Test #4
  MULS R0,R1   = $FFE8C3BC -0001522756
  SAR 16       = $FFFFFFE8 -0000000024
  SCL R0,R1    = $FFFFFFA3 -0000000093
* SAR 2        = $FFFFFFE8 -0000000024
  • cgraceycgracey Posts: 14,293
    Neither SCL or SCLU writes D. They substitute some right-shifted portion of the result into the next instruction's S value.
    SCLU multiplies D[15:0] by S[15:0] and substitutes product >> 16 into the next instruction's S value. For example:
    SCLU A,B 'Add (A[15:0] * B[15:0]) >> 16 into C
    ADD C,0
    SCL multiplies D[15:0] by S[15:0] and substitutes product ~> 14 into the next instruction's S value (~> is like SAR). For example:
    SCL A,B 'Add (A[15:0] * B[15:0]) ~> 14 into C
    ADD C,0
  • AribaAriba Posts: 2,695
    SCL makes a signed multiply and shifts the result right by 14.
    This allows fractional multiply with one factor as a signed 16bit signal and the other factor as a coefficient in the range -2.0 .. +1.99994.
    So the SAR by 2 you do in the Tests, is normally done by the correct scaling of the coefficient. $4000 correspond to 1.0.
    Fractional multiply is important for DSP application where you work mostly in the range -1.0 to +1.0, Chip wanted to have the scaling so that 1.0 is possible. And for FIR filters the coefficients can go bigger than 1.0, so +-2 is a good decision.
    The downside is that the resolution of the fractional part is only 14 bits now. For more resolution we would need a better multiplier with 18x18 bits or more.
    Andy
  • Thanks Chip & Andy for the explanation.
  • evanhevanh Posts: 17,072
    Thanks for asking the question Oz. I had wondered in the past if there was any MAC instruction shorthand. Looking good.
