$1.06 DC-DC LM2596 1.3V-35V eBay
Rated current is 2A,maximum 3A(Additional heatsink is required)
http://www.ebay.com/itm/10pcs-LM2596S-DC-DC-Buck-Converter-Adjustable-Power-Supply-Step-Down-Module-OU-/271988570314
I need a 10V 2A PSU. These look good, erco?
See also http://www.ebay.com/itm/Mini-3A-DC-DC-Converter-Adjustable-Step-down-Power-Supply-Module-replace-LM2596/291688413257
and http://www.ebay.com/itm/best-Mini-3A-DC-DC-Converter-Adjustable-Step-down-Power-Module-replace/252498344511
all 74 cents, 3A max.
I agree with you regarding the trim pots. Does anyone have experience with the step-down modules using the flimsy-looking SMT pots? Someday I will run out of my stockpile of KIS-3R33S modules and will need to find another solution.
erco - you can use those boosters to create a solar cell charging station for all of the power banks that you bought (and seduced me to buy) about a year ago.
The pic was post throw. I will stress test one next. Also since they're so cheap, I'll probably try running them in series and parallel, maybe heat sink one and drive a big load. The possibilities are endless when you have 10 and only need 3...
Do you have a test wall complete with product impressions? Personally I do this when something doesn't work right. We all have some different test procedures, as long as it works for you. :thumb:
