LORA
in Propeller 1
Hi,
I use a propeller C3 with a mdot of multitech. I use Rx and Tx pin for the communication.
The mdot's settings is attached (mdot's settings)
My code is the following :
In the first time, I don't understand why I not receive the first character of my response and sometimes the first two characters (three image that is attached (first, second and third part)) .
If anyone has a hint, I would appreciate
CON
' PROP CHIP / SYSTEM DEFINES //////////////////////////////////////////////////
' These settings are for 5 MHZ XTALS
_clkmode = xtal1 + pll16x ' enable external clock and pll times 16
_xinfreq = 5_000_000 ' set frequency to 5 MHZ
rxPin = 0
txPin = 2
mode = %0000
baudrate = 9600
relaiRouge = 3
relaiJaune = 1
Temps_attente = 3000
VAR
byte char, char1, ptr, ptr1, ptr2, AT_Reponse[200], AT_Reponse1[200], RSSI[200], SNR[200], nombre_recu
long data1, data2, data3
OBJ
pst : "Parallax Serial Terminal"
LORA : "FullDuplexserial"
PUB main
pst.Start(115200)
LORA.Start(rxPin, txPin, mode, baudrate)
data1 := 200
data2 := 1200
data3 := 2200
dira[relaiRouge] := 1
dira[relaiJaune] := 1
outa[relaiRouge] := 0
outa[relaiJaune] := 0
waitcnt(clkfreq*2+cnt)
pst.str(String("launching: ",9))
LORA.str(String("at",13))
repeat 3
Rx(Temps_attente)
pst.Str(String(13))
pst.str(String("at command: ",9))
pst.str(@AT_Reponse)
pst.Str(String(13))
waitcnt(clkfreq+cnt)
LORA.str(String("at&v",13))
repeat 49
Rx(Temps_attente)
pst.Str(String(13))
pst.str(String("at&v command: ",9))
pst.Str(@AT_Reponse)
pst.Str(String(13))
LORA.str(String("at+fsb=0",13))
repeat 3
Rx(Temps_attente)
pst.Str(String(13))
pst.str(String("at+fsb command: ",9))
pst.Str(String(13))
LORA.str(String("at+ni=1,conduit123",13))
repeat 3
Rx(Temps_attente)
pst.Str(String(13))
pst.str(String("at+ni command: ",9))
pst.Str(String(13))
LORA.str(String("at+nk=1,conduit123",13))
repeat 3
Rx(Temps_attente)
pst.Str(String(13))
pst.str(String("at+nk command: ",9))
pst.Str(String(13))
LORA.str(String("at+join",13))
repeat 3
Rx(Temps_attente)
pst.Str(String(13))
pst.str(String("at+join command: ",9))
pst.Str(String(13))
repeat
repeat 5
LORA.Str(String("at+send="))
LORA.Dec(data1)
LORA.Str(String("&RSSI="))
LORA.Dec(data2)
LORA.Str(String("&SNR="))
LORA.Dec(data3)
LORA.Str(String(13))
repeat 3
Rx(Temps_attente)
pst.Str(String(13))
pst.str(String("at+send command: ",9))
pst.Str(String(13))
if (data1 > 1000)
outa[relaiJaune] := 1
if (data1 > 2000)
outa[relaiRouge] :=1
repeat 5
LORA.Dec(data2)
repeat 3
Rx(Temps_attente)
pst.Str(String(13))
pst.Str(String(13))
if (data2 > 1000)
if (data2 > 2000)
repeat 5
LORA.Dec(data3)
repeat 3
Rx(Temps_attente)
pst.Str(String(13))
pst.Str(String(13))
if (data3 > 1000)
if (data3 > 2000)
repeat 5
LORA.Dec(data2)
repeat 3
Rx(Temps_attente)
pst.Str(String(13))
pst.Str(String(13))
if (data2 > 1000)
if (data2 > 2000)
repeat 5
LORA.Dec(data1)
repeat 3
Rx(Temps_attente)
pst.Str(String(13))
pst.Str(String(13))
if (data1 > 1000)
if (data1 > 2000)
' waitcnt(clkfreq+cnt)
PUB Rx(timeout)
Rx_LORA(timeout)
Pub Rx_LORA(timeout)
ptr := 0
if (nombre_recu == 0 OR nombre_recu == 2)
LORA.RxFlush
repeat
char := LORA.Rx
AT_Reponse[ptr++] := Char
while (char <> 13)
AT_Reponse[--ptr] := 0
elseif (nombre_recu ==1)
LORA.RxFlush
repeat
char := LORA.Rx
AT_Reponse1[ptr++] := Char
while (char <> 13)
AT_Reponse1[--ptr] := 0
else
abort
I was think about trying out these appcon LORA modules http://www.appcon.com.cn/en/product.php
