Parallax 16x2 LCD display
David Betz
in Propeller 1
I used a Parallax 16x2 LCD display in a project my son is trying to use in Africa. Of course, it is giving him trouble and I'm nowhere near there to help him figure out what is going wrong. It seems to go into its demo mode even though the baud rate switches are set to 19,200 baud. Is there anything that could cause that to happen?
When I broke mine, I couldn't find any good way to fix it short of hacking the switches off and solder globbing the terminals together, which I did not do. I only just found a permanent use for it a month or so ago, as a monitor display for my Raspberry Pi server, and 9600 baud is plenty for that (I can't see why you'd need anything higher for such a small display - it's enough to PWM the backlight intensity via serial commands).
One thing to note, the mode switches are only read are startup. If they're changed after it is powered up they won't affect anything. So if the issues with the 19,200 baud are during operation I doubt that it is the issue.
