Programming, debugging two Propellors with one Windows PC
in Propeller 1
I have a project with two prop 1 chips, each connected with a prop plug. Say one prop is COM6 and the other COM28. Each has its own program. How do I tell Propellor Tool which COM to use. I know how to tell pst which to listen to; I want to tell the Tool which to, for example, download to. Thank you for your kind attention.
Go to the operation tab and select a COM port instead of AUTO.
The Propeller tool won't use any com ports which are enabled in PST.
I select which Prop I want the Prop Tool to load by disabling the port in PST.
Edit: I should add I don't think this technique is any better than the one Chris suggested, it's just the way I've done it for years so I'm used to doing it this way.
