BlocklyProp and ActivityBoard - Terminal Input
John Kauffman
For the blocks:
Communicate/Terminal/TerminalReceiveTextStoreIn
Communicate/Terminal/TerminalReceiveNumberStoreIn
I don't see on the terminal (window titled "Console") an interface to enter text.
Any thoughts?
- Thanks.
Any thoughts?
- Thanks.
I have a thought from a prior discussion that you can actually type text into the transmit window and receive it on the Propeller Activity Board. I haven't been able to try this but I think it actually works. Maybe you can let us know.
http://blockly.parallax.com/blockly/projectlink?id=1325&key=39d6f9c4-3aa0-4864-9950-89fb2a36ba86
Enter String:
Worked
Entering an escape did not work e.g. entry of abc\tdef was displayed as abc\tdef
Accepted and returned double quotes
Enter Int:
Worked
(no additional observations)
Enter Float:
Worked
Truncated to int when displayed. This might have to do with creating float vars and nothing to do with terminal, I'm looking into it.
We chose not to support floats in Blockly because it would have required a lot of casting behind the scenes, and it would have made impossibly complex decision trees in the code generators beyond what any of us felt comfortable doing - to the point where the generated code was unreliable at best. Blocky will truncate anything float to an int. Our suggestion there is to simply multiply by powers of 10 up to the precision that you need - similar to how you would have to do math on the BS2.
No float is fine for our projects and, as you said, not hard to work around. I'm just glad to know that is the capability and not a mistake on my part.
