PDB Max3232 problems
in Propeller 1
I'm currently experimenting with some serial comms to a Pc.
Started a prop with a serial Cog, outputting a message every second at 9600, hooked up that pin to TX on the on-board max ic. Nothing on the pc, so I checked every pin with my scope, nothing but noise except for one pin that outputs steady -5v.. The prop pin however works fine!
Any ideas?
Any ideas?
But as stated before, the prop output pin works OK when listening with the scope. Its "after" the max chip that the problem seem to occur
CON _CLKMODE = XTAL1 + PLL16X _XINFREQ = 5_000_000 clockfreq = ((_CLKMODE - XTAL1) >> 6) * _XINFREQ OBJ debug : "FullDuplexSerial" PUB main debug.start(7,8,0,9600) waitcnt(clkfreq * 1 + cnt) repeat debug.str(string("Hello\n")) waitcnt(clkfreq * 1 + cnt)BTW, if you are trying to measure a signal with the meter it won't show those positive transitions, the best you will get is a slightly less negative voltage when the Prop is transmitting as the meter only gives you a DC average.
