Soldering Battery Boxes
I'm watching MacGeek117's Swarm thread about building Runt Rovers and thought I'd share a lesson learned on my last project. When soldering wires onto the type of battery holder shown below, ALWAYS remove the batteries. This idiot soldered wires to the battery box tabs with the batteries installed, and instantly had intermittent battery connections. Soldering to the small external tab softens the plastic case where the metal rivet passes through and the contacts move. In my case, the positive terminal got squished/countersunk into the plastic since the negative spring battery terminal applied steady pressure through the soldering/cooling process. Certainly a frustrating DOH moment and a dumb problem to have at 3 am when the otherwise perfect prototype is due the following morning.
Maybe that's why many kits include boxes with the wires soldered on already!
Enjoy!
Another reason to avoid these polyethylene AA battery boxes is that they will eventually crack near the ends, due to the constant negative contact spring pressure.
