SD Card Boot Testing - to be used as a basis for P2 if successful - Page 2 — Parallax Forums
2»
  • Two more results:
    Samsung microSDHC 32GB Class 10 - OK
    PNY Full-size SD 512MB - OK, detected as v1
    Cheers,
    Jesse
  • One success for me:
    "microSD HC class 4 8GB Kingston"
    SD testing v103
    Parameters used...
    4404: nCS=1    ;
    4408: 00000040 00000000 00000095 000000FF (1) 00000001 ;
    4428: 00000048 000001AA 00000087 000000FF (1) 00000001 000001AA ;
    444C: nCS=1    ;
    4450: 00000077 00000000 00000087 000000FF (1) 00000001 00000069 40000000 00000087 000000FF (1) 00000000 (9) (45720) ;
    449C: nCS=1    ;
    44A0: 0000007A 00000000 00000087 000000FF (1) 00000000 C0FF8000 ;
    44C4: nCS=1    ;
    44C8: 00000051 00000000 00000087 000000FF (1) 00000000 000000FF (170) 000000FE ;
    44F8: CRC..... 0000007C 000000BD nCS=1    ;
    4504: <eof>
    MBR sector 0...
    01C0: 03 00 0B FE FF AC 00 20 00 00 6D 8B E6 00 00 00  ....... ..m.....
    01D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
    01E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
    01F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 AA  ..............U.
    Valid MBR
    PTN 0: Typ=$0B  01BE: 00 82 03 00 0B FE FF AC 00 20 00 00 6D 8B E6 00  ......... ..m...
    PTN 1: Typ=$00  01CE: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
    PTN 2: Typ=$00  01DE: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
    PTN 3: Typ=$00  01EE: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
    SD card: 3 = SDHC/SD V2(block address)
    I also had a card that failed, but it can't be read by Windows either, so it is definitely a card problem. However, it still gives back some data (that is different than when there is no SD card). Would you be interested in the log?
    Yes please Bob.
  • SD card that can't be read by Windows:
    SD testing v103
    Parameters used...
    4404: nCS=1    ;
    444C: nCS=1    ;
    4450: 00000077 00000000 00000087 000000FF (1) 00000001 00000069 40000000 00000087 000000FF (1) 00000000 (3) (15192) ;
    449C: nCS=1    ;
    44C4: nCS=1    ;
    44C8: 00000051 00000000 00000087 000000FF (1) 00000000 33330011 <eof>
    MBR sector 0...
    01C0: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    01D0: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    01E0: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    01F0: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    Not MBR
    SD card: Unknown ???
    I can't even get Windows SDFormatter to format it.
  • evanhevanh Posts: 16,898
    I'll guess that is the same non-response of a badly seated card. But you're using v103 instead of v105, hence the variance in reported sequence. See http://forums.parallax.com/discussion/comment/1390140/#Comment_1390140
    bobjr,
    The problem is the read MBR is taking longer than 1s. I have increased the timeout to 2s and displayed the whole MBR to see if we are reading anything at all.
    Could you try v106 please?
    What is the brand, etc?
    Thanks for your assistance,
    Ray
  • Unfortunately, that didn't fix it.
    The SD card is fairly generic, I've attached a photo of both sides.
    SD testing v106
    Parameters used...
    4404: nCS=1    ;
    444C: nCS=1    ;
    4450: 00000077 00000000 00000087 000000FF (1) 00000001 00000069 40000000 00000087 000000FF (1) 00000000 (3) (15184) ;
    449C: nCS=1    ;
    44C4: nCS=1    ;
    MBR sector 0...
    0000: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    0010: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    0020: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    0030: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    0040: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    0050: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    0060: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    0070: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    0080: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    0090: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    00A0: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    00B0: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    00C0: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    00D0: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    00E0: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    00F0: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    0100: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    0110: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    0120: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    0130: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    0140: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    0150: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    0160: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    0170: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    0180: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    0190: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    01A0: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    01B0: 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99 99  ................
    Not MBR
    I honestly think the card is bad.
    1562 x 2166 - 213K
    bobjr wrote: »
    SD testing v106
    Parameters used...
    4404: nCS=1    ;
    444C: nCS=1    ;
    449C: nCS=1    ;
    44C4: nCS=1    ;
    MBR sector 0...
    Not MBR
    Yes, looks like it cannot read sector 0. The actual CMD17 is accepted to read the sector, but it never returns the start sequence for data. If we cannot read sector 0 we are dead in the water!
    Here is a new version v107.
    (for anyone who has untested cards)
    It now also reads the CSD & CID although that is not required for what we are doing.
    I am reading the CSD & CID after the MBR is read, so bobjr this will not fix your problem with that SD card.
