DIY Turbojet Engine Control RPM circuit
in BASIC Stamp
Hello fellow members,
Still plugging away at making a 300ft/lb small scale jet engine. Was wondering if anyone can enlighten me on the best way to get RPMs from a spinning shaft (up to 125K RPM) using Infrared LEDs. I have some sample code but looks like it might be limited. I'm going to paint half of a large nut gloss white and half flat black to produce the variation. I should see a 1v to 3.3v fluctuation as the shaft turns. What is the best way to get this coded? using the built in Schmitt trigger (Stamp PX2)? the attached is the circuit.
COUNT Pin, Duration, Pulses
RPM = Pulses x 60
Duration would depend on the Basic Stamp being used. For a BS2px the basic count period is 287uSec so it would be 1,000,000,/ 287 = 3,484 (actually 3,484.3205574........etc) so the reading would be low by approximately 0.001%.
