using pins P31 and P30
I have a project that is running out of pins on the propeller. I am looking at using P31 and P30 as needed extra pins. First, is that possible? Second, how does programming the chip effect those two pins usage. And does it matter if they are input or output pins after resets/programming?
Pins 28 and 29 are the I2C buss and you can easily expand (low-speed) IO with a variety of devices that can share these pins.
During testing, writing code to the Propeller would result in some goofy characters on the LCD. I could live with this interference, as it was harmless and would be almost immediately cleared when the code ran.
For anything more consequential, I would first heed Jon's suggestion to look for opportunities to expand use of existing busses (I2C, SPI ... maybe even a shift register if practical). In a real pinch, I suppose that a jumper or switch could isolate program/run functions for these pins, but that becomes quite cumbersome.
Since clock and data are always validated by an enable or latch signal then it doesn't matter if they are hooked up elsewhere, such as address line. Despite the "junk" that may seem to on these lines it is only the last valid bits that are latched anyway.
btw, I normally dual-purpose the EEPROM I2C bus pins as clock and data out so perhaps you could use P28 as your clock then P27 for your data in from the NES and P23 for the latch.
Great ideas! thank you for your help
BTW I also have an SD card connected.
The point is you can reuse the CLK (IIRC P28) if you are not toggling SDA (P29) and it will not upset EEPROM. Use P24..P26 as your Video.
This leaves you plenty of pins free for what you need.
Thank you for the reply...what type of chip is U3 on the RamBlade??
74LVC1G97DBV (RamBlade3)
I actually use ALL pins on the prop to light up 16 RGB leds.
If you do the math...
Each Led has 3 colors, and one common.
3 colors - 3 pins X 16 leds = 48 pins.
Then add 16 common legs on each led...
This equals 64 pins required.
I was able to light all 16 rgb leds using pwm.
The limit is that some of the leds cannot be lit simultaneously.
I did it by pairing up a leg on each led with another leg on a separate led, thus only requiring 32 i/o.
(64 i/o divided by 2)
Because the leds have a common, this enables you to disable any set of leds while doing work with a device on those same pins.
This device HAS an eeprom, and was programmed with all leds in circuit, using p30 and p31 with PropTool and a prop plug. This is possible because the programming procedure uses reset to start the programming process before the prop chip runs the program in eeprom.
And because my commons are tied to an I/O , they float until the program tells them not to.
Video demo:
It all really depends on WHAT devices you have connected to the pins.
Simply controlling a peripheral's VCC power supply using a prop pin, might let you reuse the rest of the peripheral's i/o for a second peripheral. Parasite power could be an issue, but if the VCC line of a peripheral is tied to gnd, using the prop i/o, i would guess the parasite power might get sucked outta the peripheral chip, letting you use the second peripheral chip as you need, powering the second peripheral chip with yet another prop i/o. Total engineering hack, dont do it if you are making a pacemaker.
In my projects, I use pin 28 as a 1MHz clock output for a 6502. The 6502 gets a lot of clocks while the Propeller is booting from the EEPROM of course, but that's not a big deal because the 6502 needs to be reset after the Propeller is running anyway.
(See https://hackaday.io/project/3620 for more info)
===Jac
I also only used single RGB pins so that grabed back a few more.
Alan
