Shift registers for propeller
in Propeller 1
I am looking for a fast (>1Mhz range, faster=better) shift registers for both input and output
And good suggestions?
Do you expect one part code to do both ?
The high-volume parts for Shifting-Out are the HC595 variants, which include TPIC6C595, TPIC6D595 etc power variants.
Shifting-In, is parts like HC597
There is also HC299, which can do Tri-state Octal Out or In, but not in any mix, and one way at a time.
Some LED driver variants can read-back, so they can do a mix of Out and In, but strangely there is no generic logic part that is designed for any mix of I/O.
With MCUs dropping in price, if you want a flexible mix of IO, in one package, then you are probably best to just use a small Micro.
I use three of the TPIC6B595 one each 8x8 array and I can get 5-bit color (on two arrays using one cog) without a noticeable flicker.
For input, I like the '165 chip since it's practically the same as the '595 chips except it's an input instead of an output. So far I've only used '165 chips with a Spin driver. I don't know if these chips have a speed limit when clocking in data
I should mention I haven't used many different kinds of shift registers so one of the chips jmg could be a better option.
