Transistor and different power source
Can i use 2 different power sources with a transistor, one source to control the base say 3.3volts and 24 volt for collector/emitter? I dont want the 24volts to affect or get to the 3.3 source (propeller pin). Also this question goes for an n channel mosfet....is this a safe setup for either a transistor or mosfet?
